Topic "Cannot open a folder if NAME is identical to parent folder"
savingface78
It appears this is a bug. One Cannot open a folder if the folder NAME is identical to parent folder name.
For example I cannot open this folder:
...\InstallMedia\InstallMedia\
-I can open the folder fine when using Windows built in FTP.
-If I rename the child folder I can open it.
-Also If I rename the parent folder, I can open the child folder.
WinSCP Version 4.2.9 Build 938
savingface78
Thanks for your reply. Here is the requested log:
. 2011-01-19 14:46:44.538 Session upkeep
. 2011-01-19 14:46:45.038 Session upkeep
. 2011-01-19 14:46:45.538 Session upkeep
. 2011-01-19 14:46:46.038 Session upkeep
. 2011-01-19 14:46:46.538 Session upkeep
. 2011-01-19 14:46:46.850 Cached directory change via "InstallMedia" to "/InstallMedia".
. 2011-01-19 14:46:46.850 Getting current directory name.
. 2011-01-19 14:46:46.850 Retrieving directory listing...
> 2011-01-19 14:46:46.850 CWD /InstallMedia/
< 2011-01-19 14:46:46.850 250 CWD command successful.
> 2011-01-19 14:46:46.850 PWD
< 2011-01-19 14:46:46.850 257 "/InstallMedia" is current directory.
> 2011-01-19 14:46:46.850 TYPE A
< 2011-01-19 14:46:46.850 200 Type set to A.
> 2011-01-19 14:46:46.850 PORT 1**,**,***,**,**,25 [(Masked for privacy)]
< 2011-01-19 14:46:46.866 200 PORT command successful.
> 2011-01-19 14:46:46.866 LIST -a
< 2011-01-19 14:46:46.866 150 Opening ASCII mode data connection for /bin/ls.
. 2011-01-19 14:46:46.866 01-05-11 06:52PM <DIR> IndividualInstallers
. 2011-01-19 14:46:46.866 12-22-10 05:31PM <DIR> InstallMedia
. 2011-01-19 14:46:46.866 10-13-10 12:55PM <DIR> OracleInstallMedia
. 2011-01-19 14:46:46.866 07-07-10 10:24AM <DIR> SoftwareUpdaters
< 2011-01-19 14:46:47.007 226 Transfer complete.
. 2011-01-19 14:46:47.007 Directory listing successful
. 2011-01-19 14:46:47.007 Got reply 1 to the command 2
. 2011-01-19 14:46:47.038 Session upkeep
. 2011-01-19 14:46:47.538 Session upkeep
. 2011-01-19 14:46:48.038 Session upkeep
. 2011-01-19 14:46:48.538 Session upkeep
. 2011-01-19 14:46:48.538 Cached directory change via "InstallMedia" to "/InstallMedia".
. 2011-01-19 14:46:48.538 Getting current directory name.
. 2011-01-19 14:46:48.538 Directory content loaded from cache.
. 2011-01-19 14:46:49.038 Session upkeep
. 2011-01-19 14:46:49.538 Session upkeep
. 2011-01-19 14:46:50.038 Session upkeep
. 2011-01-19 14:46:50.538 Session upkeep
. 2011-01-19 14:46:51.038 Session upkeep
. 2011-01-19 14:46:51.538 Session upkeep
. 2011-01-19 14:46:52.038 Session upkeep
. 2011-01-19 14:46:52.538 Session upkeep
. 2011-01-19 14:46:53.038 Session upkeep
. 2011-01-19 14:46:53.538 Session upkeep
. 2011-01-19 14:46:54.163 Got reply 1004 to the command 2
. 2011-01-19 14:46:54.163 Disconnected from server
I have sent you an email.
savingface78
Hi Martin,
I've replied to your email with the debug file. It seems to work with the files you gave me.
savingface78
The problem seems to lay with my old INI file.
It works as long as I don't use my previous INI file. If I allow your 2 new files you sent me to create a new INI file, and then choose to save the password it will work.
From the log it looks like it may be connected to directory change cache (which is stored in the INI file). If it ever happens again, please let me know.
savingface78
Sorry for the slow reply, the notification went to my spam folder. Thanks for your help with this - much appreciated.
