Topic "copy faild"
baramann72
hi@all,
i try to copy a file via scp over an exsisting one, but i get allways
. 2011-01-21 21:35:34.875 Enumerating network events for socket 468
. 2011-01-21 21:35:34.875 Enumerated 1 network events making 1 cumulative events for socket 468
. 2011-01-21 21:35:34.875 Handling network read event on socket 468 with error 0
. 2011-01-21 21:35:34.875 Received 87 bytes (0)
. 2011-01-21 21:35:34.875 Read 1 bytes (86 pending)
. 2011-01-21 21:35:34.875 Read 86 bytes (0 pending)
< 2011-01-21 21:35:34.875 scp: /webshop/templates/de/kaputt_eve.htm: set times: Operation not permitted
. 2011-01-21 21:35:34.875 SCP remote side error (1):
. 2011-01-21 21:35:35.578 Session upkeep
. 2011-01-21 21:35:35.578 Looking for network events
. 2011-01-21 21:35:35.578 Timeout waiting for network events
a look to the filesystem at the server:
ls -aln
-rw-rw-r-- 1 10014 10017 15 Jan 21 21:30 kaputt_eve.htm
server:/webshop/templates/de # su - xxxx
tsambiasi@wwt64-2:~> id
uid=10013(xxxx) gid=10017(g_update) Gruppen=10016(g_templater),10017(g_update)
xxxx@server:~>
Remoteserver is linux sles 11
WinSCP V4.2.9 (Build938) on WinXP
scp via putty works without problem:
baramann@cts0017358-2 /cygdrive/d/CTS/logs/ln
$ scp serch ad-auth.net\\xxxx@server:/webshop/templates/de/kaputt.htm
Password:
serch 100% 45 0.0KB/s 00:00
any ideas?
thanks
bjoern
baramann
hi,
i found a solution. When i set "Ignore permissions errors" it works.
Question:
1. why there are permissions error which cygwin is not display?
2. Is it possible to set this option in a saved connection?
3. When I copy a file direct on the server (cp xx to xx) it works also without problems
thanks
bjoern
You have Preserve time option set, what causes the error. You would see the same with cygwin if you use -p switch.
You can set it in preferences.
