Topic "Help! Photos won't sync to my iPhone"
carol10001
Hello,everyone!I am trying to sync my photos to my iphone. In itunes, I am able to check the box to sync, then check to sync a particular folder. After that I have tried clicking on Apply AND File>Sync iphone and then the photo box will gray out and the photos will not sync. I have tried different USB ports.I'm desperate any help would be appreciated...
Did you check if you have the correct folder to Sync you photos?
allen05
We create a daily file that I need to upload to a vendor. I can hard code the file name and that works but it changes daily so I need to send a file like:
c:\myfilepath\myFile_20130122.txt where the date portion changes daily and needs to be yyyymmdd.
I am not having luck with that part. Any help is appreciated.
jimmy
