Topic "Username in batch script retrieval"
Whykonen
I'm trying to retrieve the username of a stored session, to use in the batch script.
Is there a parameter to retrieve UserName as defined in winscp.ini?
Thanks in advance!
Script:
IF EXIST "C:\Users" goto nietwinxp
IF EXIST "C:\Documents and Settings" goto winxp
:nietwinxp
echo nietwinxp
winscp.com /script=nietwinxp.txt
if errorlevel 1 goto error
goto end
:winxp
echo winxp
winscp.com /script=winxp.txt
goto end
:error
cscript sendmail.vbs addresseddude@provider.com "subject line" "Content, username here"
:end
PAUSE
[/code]
Whykonen
Fixed the problem, i used
for /F "delims=" %%a in ('findstr /c:UserName WinSCP.ini') do set username=%%a
