Topic "Host is not communicating for more than 15 seconds...."
mbottel
I am using a SSIS package to run WINscp to get a file from our GlabalScape server and copy it locally for processing. When i run the collowing command, i get the "Host is not communicating for more than 15 seconds. Still waiting... Warning: Aborting this operation will close connection!" warning. If i type A to abort, it finishes without error.... I am confused. I need this to run automatically and not require me to type A to abort.
The executable: D:\Program Files\WinSCP\WinSCP\WinSCP.com
The Script: winscp.com /command "open RPA" "get some.dumb.file.txt" "exit"
Any help or ideas would be appreciated. If i run this manually from a cmd prompt, it runs fine.
Micth
mbottel
The Log.....
. 2011-02-01 15:24:13.759 --------------------------------------------------------------------------
. 2011-02-01 15:24:13.759 WinSCP Version 4.2.7 (Build 758) (OS 5.2.3790 Service Pack 2)
. 2011-02-01 15:24:13.759 Login time: Tuesday, February 01, 2011 3:24:13 PM
. 2011-02-01 15:24:13.759 Session name: RPA
. 2011-02-01 15:24:13.759 Host name: SomeIP (Port: 22)
. 2011-02-01 15:24:13.759 User name: Johnson (Password: Yes, Key file: No)
. 2011-02-01 15:24:13.759 Tunnel: No
. 2011-02-01 15:24:13.759 Transfer Protocol: SFTP (SCP)
. 2011-02-01 15:24:13.759 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2011-02-01 15:24:13.759 Proxy: none
. 2011-02-01 15:24:13.759 SSH protocol version: 2; Compression: No
. 2011-02-01 15:24:13.759 Bypass authentication: No
. 2011-02-01 15:24:13.759 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: No; GSSAPI: Yes
. 2011-02-01 15:24:13.759 GSSAPI: Forwarding: No; Server realm:
. 2011-02-01 15:24:13.759 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2011-02-01 15:24:13.759 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2011-02-01 15:24:13.759 SFTP Bugs: -,-
. 2011-02-01 15:24:13.759 Return code variable: Autodetect; Lookup user groups: Yes
. 2011-02-01 15:24:13.759 Shell: default, EOL: 0
. 2011-02-01 15:24:13.759 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2011-02-01 15:24:13.759 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2011-02-01 15:24:13.759 Local directory: D:\MSSQL\90\DTS\Packages\RPA_Reconcile\InputFiles, Remote directory: /, Update: No, Cache: Yes
. 2011-02-01 15:24:13.759 Cache directory changes: Yes, Permanent: Yes
. 2011-02-01 15:24:13.759 DST mode: 1
. 2011-02-01 15:24:13.759 Looking up host "SomeIP"
. 2011-02-01 15:24:13.759 Connecting to 10.224.8.89 port 22
. 2011-02-01 15:24:13.759 Server version: SSH-2.0-1.36_sshlib GlobalSCAPE
. 2011-02-01 15:24:13.759 We believe remote version ignores SSH-2 maximum packet size
. 2011-02-01 15:24:13.759 Using SSH protocol version 2
. 2011-02-01 15:24:13.759 We claim version: SSH-2.0-WinSCP_release_4.2.7
. 2011-02-01 15:24:13.775 Doing Diffie-Hellman group exchange
. 2011-02-01 15:24:13.775 Doing Diffie-Hellman key exchange with hash SHA-1
. 2011-02-01 15:24:13.900 Host key fingerprint is:
. 2011-02-01 15:24:13.900 ssh-dss 2048 86:7f:73:95:86:e0:d9:b8:d0:ed:3c:0f:08:c6:9a:bc
. 2011-02-01 15:24:13.900 Initialised AES-128 CBC client->server encryption
. 2011-02-01 15:24:13.900 Initialised HMAC-SHA1 client->server MAC algorithm
. 2011-02-01 15:24:13.900 Initialised AES-128 CBC server->client encryption
. 2011-02-01 15:24:13.900 Initialised HMAC-SHA1 server->client MAC algorithm
! 2011-02-01 15:24:14.088 Using username "Johnson".
. 2011-02-01 15:24:14.103 Prompt (6, SSH password, , &Password: )
. 2011-02-01 15:24:14.103 Using stored password.
. 2011-02-01 15:24:14.103 Sent password
. 2011-02-01 15:24:14.119 Access granted
. 2011-02-01 15:24:14.119 Opened channel for session
. 2011-02-01 15:24:14.291 Started a shell/command
. 2011-02-01 15:24:14.291 --------------------------------------------------------------------------
. 2011-02-01 15:24:14.291 Using SFTP protocol.
. 2011-02-01 15:24:14.291 Doing startup conversation with host.
> 2011-02-01 15:24:14.291 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2011-02-01 15:24:14.291 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2011-02-01 15:24:14.291 SFTP version 3 negotiated.
. 2011-02-01 15:24:14.291 We believe the server has signed timestamps bug
. 2011-02-01 15:24:14.291 We will use UTF-8 strings for status messages only
. 2011-02-01 15:24:14.306 Changing directory to "/".
. 2011-02-01 15:24:14.306 Getting real path for '/'
> 2011-02-01 15:24:14.306 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2011-02-01 15:24:14.306 Type: SSH_FXP_NAME, Size: 23, Number: 16
. 2011-02-01 15:24:14.306 Real path is '/'
. 2011-02-01 15:24:14.306 Trying to open directory "/".
> 2011-02-01 15:24:14.306 Type: SSH_FXP_LSTAT, Size: 10, Number: 263
< 2011-02-01 15:24:14.306 Type: SSH_FXP_ATTRS, Size: 21, Number: 263
. 2011-02-01 15:24:14.306 Getting current directory name.
. 2011-02-01 15:24:14.306 Startup conversation with host finished.
. 2011-02-01 15:24:14.306 Listing file "SomeFile".
> 2011-02-01 15:24:14.306 Type: SSH_FXP_LSTAT, Size: 39, Number: 519
< 2011-02-01 15:24:14.306 Type: SSH_FXP_ATTRS, Size: 29, Number: 519
. 2011-02-01 15:24:14.306 File: "/SomeFile"
. 2011-02-01 15:24:14.306 Copying "/SomeFile" to local directory started.
. 2011-02-01 15:24:14.306 Binary transfer mode selected.
. 2011-02-01 15:24:14.306 Checking existence of partially transfered file.
. 2011-02-01 15:24:14.306 Opening remote file.
> 2011-02-01 15:24:14.306 Type: SSH_FXP_OPEN, Size: 47, Number: 771
< 2011-02-01 15:24:14.306 Type: SSH_FXP_HANDLE, Size: 10, Number: 771
> 2011-02-01 15:24:14.306 Type: SSH_FXP_FSTAT, Size: 10, Number: 1032
> 2011-02-01 15:24:14.306 Type: SSH_FXP_READ, Size: 22, Number: 1285
. 2011-02-01 15:24:14.306 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
< 2011-02-01 15:24:14.306 Type: SSH_FXP_ATTRS, Size: 29, Number: 1032
. 2011-02-01 15:24:14.306 Storing reserved response
< 2011-02-01 15:24:14.416 Status code: 1
. 2011-02-01 15:24:14.416 47 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-02-01 15:24:14.416 Type: SSH_FXP_CLOSE, Size: 10, Number: 8196
< 2011-02-01 15:24:14.416 Type: SSH_FXP_STATUS, Size: 22, Number: 7429
< 2011-02-01 15:24:14.416 Type: SSH_FXP_STATUS, Size: 22, Number: 7685
< 2011-02-01 15:24:14.416 Type: SSH_FXP_STATUS, Size: 22, Number: 7941
. 2011-02-01 15:24:14.416 Closing connection.
. 2011-02-01 15:24:14.416 Sending special code: 12
. 2011-02-01 15:24:14.416 Sent EOF message
I do not see any error in the log file.
mbottel
I sent you a email with more results and screen shots.
Thanks for your help....
