Topic "Problem Uploading [9361]"
siddiqir
Hello, I am for some reason unable to you -append switch with put command in a script
"C:\Program Files\WinSCP\winscp.com" /script=upload.txt
option batch continue
open xyz
put -append c:\hello.txt /NewYork/
log file says
Unknown switch 'append'.
Make sure you are using the latest version. Switch -append is supported since 4.2.2 only.
Siddiqir
Thank you very much. I was on v4.1.8. Just updated to 4.3.0. I will re-try.
