Topic "Problem Deleting on remote server using console or batch"
amnonliberman
Hello
I am using WinScp 4.2.9 for sftp
When trying to delete a file on the remote server - using the GUI I am successful.
When using console rm command, either with single quote or without, I am unable to delete.
this the session console.
Searching for host...
Host does not exist
batch           on
confirm         off
Connecting to host...
Authenticating...
Using username "****".
Authenticated.
Starting the session...
Reading remote directory...
Session started.
Active session: [1] ****@stageftp.fiftyone.com
/outbox/orders
Error deleting file '/outbox/orders/2011-01-24-14-55-34-PO-E4X000000495717.xml.a
sc'.
General failure (server should provide error description).
Error code: 4
Error message from server (en): error deleting file
Request code: 13
drw-rw-rw-   3 user     group            0 Jan 31 11:22:41 2011 .
-rw-rw-rw-   1 user     group         6500 Jan 28 21:38:22 2011 2011-01-24-14-55
-34-PO-E4X000000495717.xml.asc
drw-rw-rw-   3 user     group            0 Jan 25 23:27:44 2011 Archive
-rw-rw-rw-   1 user     group         6500 Jan 28 10:23:27 2011 _2011-01-24-14-5
5-34-PO-E4X000000495717.xml.asc
winscp>
I am using the following command to invoke winscp:
c:\WinSCP\WinSCP.exe winscp.exe /console /script=fcom.txt /log="C:\winscp.log"
My Batch Script is as follow:
# Automatically answer all prompts negatively not to stall
# the script on errors
option batch on
# Connect using a password
# open user:password@example.com
# Connect:
open sftp://User:Password@stageftp.fiftyone.com
# Change remote directory
cd /outbox/orders
rm  /outbox/orders/2011-01-24-14-55-34-PO-E4X000000495717.xml.asc
dir
#close
# Disconnect
I pasted my logs for the GUI here -
http://pastebin.com/5DJAVLx8
Console/batch Log -
http://pastebin.com/vXfGjcUp
Ini File
http://pastebin.com/JwL4UWqf
I'm sorry for late answer. In GUI you are removing different files than in console. Can you post a log files showing removal of the same file?
amnonliberman
Thanks from replying - the problem was found - it was case difference, outbox instead on Outbox.
