Topic "WinSCP and WS_FTP"
jko5
Hello. I seem to be having a very similar problem as another user. I am trying to connect WinSCP to WS_FTP using SFTP. I have no issues connecting with FTP or if I use Filezilla I can connect using both SFTP and FTP. Here is the log file for WinSCP. I realize it must be a simple setting that I am missing but I am not sure what it is. Please help!
WinSCP Version 4.2.9 (Build 938) (OS 6.1.7600)
. 2011-01-31 08:21:22.931 Login time: Monday, January 31, 2011 8:21:22 AM
. 2011-01-31 08:21:22.931 --------------------------------------------------------------------------
. 2011-01-31 08:21:22.931 Session name: orendj@w7dorendj.oec.oeconnection.com
. 2011-01-31 08:21:22.931 Host name: w7dorendj.oec.oeconnection.com (Port: 22)
. 2011-01-31 08:21:22.931 User name: orensj (Password: Yes, Key file: Yes)
. 2011-01-31 08:21:22.931 Tunnel: No
. 2011-01-31 08:21:22.931 Transfer Protocol: SFTP (SCP)
. 2011-01-31 08:21:22.931 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2011-01-31 08:21:22.931 Proxy: none
. 2011-01-31 08:21:22.931 SSH protocol version: 2; Compression: No
. 2011-01-31 08:21:22.931 Bypass authentication: No
. 2011-01-31 08:21:22.931 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2011-01-31 08:21:22.931 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2011-01-31 08:21:22.931 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2011-01-31 08:21:22.931 SFTP Bugs: -,-
. 2011-01-31 08:21:22.931 Return code variable: Autodetect; Lookup user groups: Yes
. 2011-01-31 08:21:22.931 Shell: default
. 2011-01-31 08:21:22.931 EOL: 0, UTF: 2
. 2011-01-31 08:21:22.931 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2011-01-31 08:21:22.931 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2011-01-31 08:21:22.931 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2011-01-31 08:21:22.932 Cache directory changes: Yes, Permanent: Yes
. 2011-01-31 08:21:22.932 DST mode: 1
. 2011-01-31 08:21:22.932 --------------------------------------------------------------------------
. 2011-01-31 08:21:22.950 Looking up host "w7dorendj.oec.oeconnection.com"
. 2011-01-31 08:21:22.950 Connecting to fe80::e5f9:7fc4:c43d:eb5%11 port 22
. 2011-01-31 08:21:23.950 Failed to connect to fe80::e5f9:7fc4:c43d:eb5%11: Network error: Connection refused
. 2011-01-31 08:21:23.950 Connecting to fe80::e5f9:7fc4:c43d:eb5%11 port 22
. 2011-01-31 08:21:24.951 Failed to connect to fe80::e5f9:7fc4:c43d:eb5%11: Network error: Connection refused
. 2011-01-31 08:21:24.951 Connecting to fe80::e5f9:7fc4:c43d:eb5%11 port 22
. 2011-01-31 08:21:24.951 Attempt to close connection due to fatal exception:
* 2011-01-31 08:21:24.951 Network error: Connection refused.
. 2011-01-31 08:21:24.951 Closing connection.
. 2011-01-31 08:21:24.951 Sending special code: 12
* 2011-01-31 08:21:24.954 (ESshFatal) Network error: Connection refused.
Can you post a log file from Filezilla SFTP session?
Hey Martin. This is all the log file shows from Filezilla.
2011-02-02 12:54:07 2776 2 Status: Connecting to w7dorendj.oec.oeconnection.com...
2011-02-02 12:54:07 2776 2 Response: fzSftp started
2011-02-02 12:54:07 2776 2 Command: keyfile "C:\Users\orendj\Desktop\private.ppk"
2011-02-02 12:54:07 2776 2 Command: open "orendj@w7dorendj.oec.oeconnection.com" 22
2011-02-02 12:54:09 2776 2 Command: Trust new Hostkey: Once
2011-02-02 12:54:09 2776 2 Status: Connected to W7DORENDJ.oec.oeconnection.com
2011-02-02 12:54:09 2776 2 Status: Retrieving directory listing...
2011-02-02 12:54:09 2776 2 Command: pwd
2011-02-02 12:54:09 2776 2 Response: Current directory is: "/users/orendj"
2011-02-02 12:54:09 2776 2 Command: ls
2011-02-02 12:54:09 2776 2 Status: Listing directory /users/orendj
2011-02-02 12:54:09 2776 2 Status: Directory listing successful
In FileZilla, please go to Edit > Settings > Debug and set Debug information in message log to 2 - Info. Restart Filezilla and generate new log file.
