Topic "problem with ssh compression"
mahmood
I have enabled compression in SSH->protocol options, but after connecting to remote host, the zip icon in the bottom of page (near connection time) is gray.
What is the problem?
Your server may not support it.
Check the log file.
mahmood
1) how can I check on server side?
2) I enabled the debug mode level 2 and after login, I opened the log file. I didn't any error or warning that complain about compression. If you give me a clue, I will see that again. I should search for what in log file?
This issue is being tracked.
golimar
I think the bug is fixed in Putty, I'm using compression right now with r9125.
If you use this version for the next release of WinSCP, will it support compression winth SFTP?
