Topic "Can the Winscp plugin cause a Far UAC prompt if necessary"
zippy1981
For the past few versions, Far 2.0 has an internal UAC prompt of sorts if performing a local file operation See http://www.justaprogrammer.net/wp-content/uploads/2010/12/Access-denied-Far-2.0.png. It does not seem to get triggered by the winscp plugin when I want to copy from a sftp share to a local folder that requires admin access. Is it possible to add this feature?
Regards,
Justin Dearing
Thanks for your post. I'll check it.
justyjusty123
I also noticed this issue: I downloaded files and cound not find them in a directory. WinSCP did not send notifications for this.
justyjusty123
Dear Martin,
I just wanted add that I recognized this issue (copying file from one tree to a 64bit-Windows host) with both the stable version 4.53 as well as with the Beta, 5.0.6
As we use WinSCP a lot, we are looking forward for a solution for this. You can contact me any time with questions for details.
Please direct your request for Far-NetBox project:
https://github.com/michaellukashov/Far-NetBox
