Topic "Rename - Strange behaviour"
cozappz
Win XP SP3, WinSCP 4.3.1 build 1099 using Commander interface with tree above filelist for remote panel.
The rename action does not work as expected:
Once the connection to the remote server has been established, clicking on local panel and hitting F2 does not start the rename action on the focused file.(The right-click shows a menu missing rename option)
In the remote panel, F2 does not work on focused file, Rename option from right-click menu does not work.
May this be related to Bug# 570 and Bug# 640 ?
Thanks for your post. This bug has been added to tracker.
