Topic "Explorer view - .. shortcut to parent"
I was wondering if there is a way to get the .. shortcut to go up one level to the parent directory in the main window in Explorer view? Commander view has this, but I prefer Explorer view as I do not use the Local panel too often.
Thanks!
There's no way. You can use many other ways to get to parent directory. Backspace key, Ctrl+PgUp, toolbar icon.
Okay, thanks! I just find the .. shortcut to be the easiest to use. Smile
Yury Plashenkov
Dear Martin,
Is there any chance you will add the option to show a ".." (parent folder) shortcut in Explorer view?
It would be very nice. Sometimes I drag and drop files to this shortcut to move them to a parent folder, but since I switched to Explorer view, I cannot do this. Sure, there is a perfect folder tree in Explorer view, but I think the option to show ".." will not be excess.
Thank you and good luck!
Sincerely,
Yury Plashenkov
Thanks for your post.
This request has been added to the tracker:
http://winscp.net/tracker/show_bug.cgi?id=835
MPLewis
Has any progress been made on this issue? Having the ability to go back up a directory in the explorer window would be fantastic for me.
