Topic "Log file not generating."
wmb853
I am working on an issue and need to generate a log file. I am running WinSCP from a bat file below:
c:\WinSCP\WinSCP3.exe /console /script="c:\EMT\AutoFTP.txt" /log="C:\EMT\winscp.log"
No log file ever gets generated. Thanks.
Can you try it with the latest version?
I just upgraded to the latest version. I never see the winscp.log file get created in the C:\EMT folder or anywhere else.
Thanks!
Bill
I should also clarify that the FTP upload is working correctly. I just don't get a log file.
Alex2011
I have the same problem...
Have you got a soluttion
Have you got a solution
That's ok now !
tdguitar
I have a function with creating log xml file like below. It run well on local machine, but when I publish it to be used as client-server, it can not create a log file. Please help me to check it.
const string logname = "log.xml";
Process winscp = new Process();
winscp.StartInfo.FileName = "C:\\Program Files\\WinSCP\\winscp.com";
winscp.StartInfo.Arguments = "/log=C:\\"" + logname + "\"";
winscp.StartInfo.UseShellExecute = false;
winscp.StartInfo.CreateNoWindow = true;
winscp.Start();
winscp.StandardInput.WriteLine("option batch abort");
winscp.StandardInput.WriteLine("option confirm off");
winscp.StandardInput.WriteLine("open mysession");
winscp.StandardInput.WriteLine("ls");
winscp.StandardInput.Close();
string output = winscp.StandardOutput.ReadToEnd();
winscp.WaitForExit();
XPathDocument log = new XPathDocument(logname);
XmlNamespaceManager ns = new XmlNamespaceManager(new NameTable());
ns.AddNamespace("w", "http://winscp.net/schema/session/1.0");
XPathNavigator nav = log.CreateNavigator();
XPathNodeIterator files = nav.Select("//w:file", ns);
Console.WriteLine(string.Format("There are {0} files and subdirectories:", files.Count));
    foreach (XPathNavigator file in files)
        Console.WriteLine(file.SelectSingleNode("w:filename/@value", ns).Value);
tdguitar
winscp.Start();
No one answer me the problem Sad
Make sure the account that runs the script has write access to C:\
