Topic "Bad Packet Lenght"
!Alex!
i try to copy a file from my Windows 7 to my server.
The filesize is for Example 71kB.
But i got this error:
After that the filesize on the server is 65536 Bytes.
If i try to copy the same file from another PC (Windows 7), it works.
My WinSCP-Version is 4.3.2 Build 1201
Whats the problem?
Please post a full log file (Debug Level 2) showing the problem.
!Alex!
Where do I find the logfile or how can I create a logfile?
Follow the link in my previous post.
!Alex!
Thank you.
Here is the log: http://pastebin.com/kKaTChRy
