Topic "Transferfiles are different in size /corrupted"
VSftp on server side (linux)
Winscp on clientside (server2003)
transfermode 4 all: binary
Transfer over explizit FTP with ssl encryption
Some files are not transferred correcly. On Serverside they are corrupted. Files size differs from server. Seems if the transfer got a too early "end of transfer" code.
Tested also wiht text mode, auto mode. no effect.
Any hints?
