Topic "Cant read Unisys mainframe directory"
Im using WINSCP 4.2.9 (Build 938) to transfer files from a Windows 7 station to a UNISYS mainframe CS 690. All the times WINSCP couldnt read the UNISYS directory and I couldnt check if the file was transferred (I have to go to UNISYS mainframe to check this). Please let me know:
1. if this issue was fixed on versions newer than 4.2.9, and if it was not yet if are in the plains to future versions.
2. Are there some workaround for this issue?
Thanks in advance,
