Topic "Unknown command '_o'"
raimiansch
Hello together!
I want to automate file trasfer with winscp. But I always get the error
I use following command:
.\WinSCP.com /script=scp.txt
The content of scp.txt is:
option batch on
open nabackup@x9149.spar.local.at
bin
put C:\adm\VMbackup\VMware-ESX-aecpitsp01
put C:\adm\VMbackup\VMware-ESX-atsl-dmgr01
put C:\adm\VMbackup\VMware-ESX-atsl-ecpa02
The output is:
C:\Program Files (x86)\WinSCP> .\WinSCP.com /script=scp.txt
Unknown command '_o'.
winscp>
When I open the winscp console (winscp.com) and try each command per hand, it works very fine.
I use the version
C:\Program Files (x86)\WinSCP>WinSCP.com /h
WinSCP, Version 4.3.2 (Build 1201)
Copyright (c) 2000-2011 Martin Prikryl
Can anybody help me please?
Rainer
Make sure the script file is saved using UTF8 encoding.
raimiansch
Thank you for your help.
I used within powershell following code to create the text file.
echo "option batch on" >>scpcmd
echo "option confirm off" >>scpcmd
echo "open nabackup@x9149.spar.local.at" >>scpcmd
Now I use set-content instead of ">>scpcmd" and it works fine.
Thank you
Rainer
Basic PowerShell example added
http://winscp.net/eng/docs/library#powershell
More examples (and syntax highlighting) coming soon.
