Topic "Assertion failed: xdrPtr && xdrPtr == *xdrLPP, file xx.cpp, line 2233"
blackcat
Hy. when I use scp and sftp from my winxp to the same linux server, uploading large files, I constantly get this message in the subject randomly while uploading. after this: abnormal program termination
There is not such assertion in the application. Are you sure that you have posted the actual error message? Please use Ctrl+C to copy exact message and paste it to the post. Also what version of WinSCP are you using?
darcan
I have the same error.
WinSCP3.exe
OK
My OS: Win XP.
Uploading to linux.
WinSCP 3.5
I'll look at it. But I have not idea yet what may cause this.
I am getting this exact error as well.
Me 3 said the flea. the other i see continuosuly but it runs through it.
<img src='http://www.corriebeth.com/error2.bmp'><br>
<img src='http://www.corriebeth.com/error.bmp'><br>
win2k
GPHemsley
Yup, I'm getting the same error with the latest version.
Local OS: Windows XP Professional
Remote Host: projects.sourceforge.net
Error:
and after clicking OK:
Quote:
Abnormal program termination
To all: Under what circumstances do you get the error? Is it also while uploading large files as "blackcat" reports?
Receiving the same error. Intermittent with any kind of folder/files to a Linux box. The error is consistent even if it occurs at differing times during transfer.
NOTE: Frustrated, I returned to using WinSCP 2 and had no further problems. I was unable to reproduce the problem transfering the same files to the same host. Delete the folder, and try again with WinSCP 3.5, and error returns.
What can I do to assist?
Richard Harmonson
MCSE/CNE/RHCE
In answer to your above question re: large files. I was transfering three files ranging from 1 to 3 mb. Nothing larger.
Richard Harmonson
MCSE/CNE/RHCE[/quote]
I would appreciate if you can try newer version (like 3.0) to determine when the problem was introduced. The error never happens to me so I have no idea what may cause this.
Thanks in advance. Please let me know.
Be happy to try WinSCP 3, but not seeing it as an available download. I may be going blind. Where?
I will test tonight and post results.
Richard Harmonson
richard at kinetotech dot com
All old versions of WinSCP are on the Sourceforge download server. The link is on Downloads page.
Thanks in advance. If you are able to reproduce the bug easily, than I would ask you to try more versions to find one that introduced the bug. If it is not easy than try only 3.0 now. If it is fine, I'll try to suggest some other that may have been the first faulty.
Avenger
Desktop OS: WinXP with WinSCP 3.5.0
Server OS: Fedora Core 1
It is reproducable 100% for me if I try to upload 10 directories to an empty directory on the server. I am also getting "Null Pointer Termination" dialog boxes appearing at random times.
WinSCP 3.4.2 is currently uploading the same files to the same empty directory without any problems at all.
--Keith
Thanks!
This might help. I'm able to reproduce the error now. I need to try it in the evening at home with debugger. I hope it will be reproducible there to.
It also happens to me only with 3.5, not with 3.4.2 and mainly not with upcoming version of WinSCP (3.5.5).
If others can confirm that the error happens only with 3.5, I would appreciate it.
GPHemsley
The error did not occur with 3.4.2. Mr. Green
Thanks! That's good. I believe that the bug is then releated to another problems introduced in 3.5 like
- Problem with 3.5 version
- V3.5 under w2k and wxp can't change to /cygdrive - access failure
So it will be fixed in the next release (in fact it is already).
Sorry for the delay, but once I had a working WinSCP, I was busy using it to complete a large migration.
WinSCP 3.4.2 worked perfectly. I moved over 250 gb without issue. Not a single error.
Thank you!
Richard Harmonson, CNE/MCSE/RHCE
iRex
Can you tell us when the version with the fix will be available?
Thanks.
PS This is an incredible piece of software, even for a a "non-programmer"
At the end of this week.
Will that be WinSCP3 v.3.5.1?
David
getting same error
That will be 3.5.5. But I do not understand what difference it makes to you? Question
me
not sure if this is where to place this but I get the following error
access violation at address 0055bcf1 in module 'winscp3.exe'. read of address ff00000c
winscp3 ver 3.5 build 204 drag and dropped the folder with files in it to thhe remote location
scp/sftp root priveledges on remote and admin privledges on local
win 2k professional uploading to aa linux carton
Can you reproduce the error with the latest version (3.5.6)?
PollyVinylChloride
I've been evaluating the Java SSH Daemon which comes with an open-source package known as SSHTools. I've successfully logged into the daemon using Cygwin SSH and Putty. I've also successfully accessed the daemon's SFTP subsystem using the Cygwin SFTP client. However, although I can successfully authenticate to the Java daemon using WinSCP, I cannot proceed beyond that point. The session times out, every time. I have tried increasing the timeout interval without success.
I've logged both the WinSCP and Cygwin SFTP sessions, but as I'm ignorant of the protocol, the log doesn't mean that much to me.
There is a point at which something seems obviously to fail, and the following is an excerpt from the WinSCP log at this point:
> Type: SSH_FXP_INIT, Size: 5, Number: -1
. Waiting for data timed out, asking user what to do.
If you have any suggestions as to how I might proceed, I would be most grateful.
First of all, try to enable logging on the SFTP server side, if the server allows it. Post the log.
MichaelMR2
I'm getting this exact error again, Version 4.3.2 Neutral
prikryl wrote:
For what it is worth, I just receive this error as well with v4.3.6; Trying the 5.0.5 Beta right now... This was on a 64-bit Windows 2008 R2 with a relative large file 75mb.
Please let us know results of your 5.0.5 test.
