Topic "No directory listing with AUTH SSL"
sunfish
Hi Martin,
I get an error, if I try to connect with FTP SSL in passive mode with WinSCP. There are no problems with FileZilla. There is a difference between both logs.
WinSCP:
PWD
257 "/" is the current directory
Retrieving directory listing...
TYPE A
200 Type set to A
PASV
227 Entering Passive Mode (85,158,176,225,132,209).
LIST -a
150 Opening ASCII mode data connection for file list
SSL connection established
425 Unable to build data connection: Operation not permitted
FileZilla:
answer: 257 "/" is the current directory
command: TYPE I
answer: 200 Type set to I
command: PASV
answer: 227 Entering Passive Mode (85,158,176,225,163,118).
command: MLSD
command: 150 Opening ASCII mode data connection for MLSD
answer: 226 Transfer complete
Can you get the clue?
By the way: your WimSCP is a great piece of software.
May I have a test account on your server?
Yes, I have send you the account data via PM.
