Topic "winscp freezes"
peto
I use winscp mainly for FTP sites. And this error occoures very often, when winscp is connected and idle for some time. First, it gives me error like timeout and then I get this error:
Error getting name of current remote directory
Invalid response to PWD command 'MDTM
MFMT
TVFS
MFF modify;UNIX.group;UNIX.mode;
MLST modify*;perm*;size*;type*;unique*;UNIX.group*;UNIX.mode*;UNIX.owner*;
REST STREAM
SIZE
I click OK and then winscp tries to reconnect (probably) - I can see only small blank window and whole program is frozen. Only way to close it is to kill winscp.exe via taskmanager or similar program.
I use FTP protocol with passive mode and this happens not only on one server.
Am I doing something wrong?
peto
sorry, I forgot
WinSCP version: 4.3.2
(before this version, I was using ver 4.2.9 and I didnt noticed this bug, but I am not sure)
Windows Vista SP2
peto
I have sent you mail
Itaku
I sent an email too, since I've been getting the same errors and problems.
elraver
I'm sending you my email for a debug version as well due to having this issue. It simply freezes seemingly at random. I'll go to do some editing on a file for about 10 minutes, and when I come back to the WinSCP window to upload it, it is frozen (Not Responding) and has to be killed and reopened.
-elraver
neijygof
I am having the same problem... may I send you an e-mail requesting the debug version?
Thank you in advance,
neijygof
Sure. But first, pleae make sure you are using the latest version of WinSCP.
kag
I'm having the same problem and I'm running 4.3.3 build 1340 on Windows XP SP3.
I have sent you an email.
consistency
i have a similar "problem" with ssh connections (for all my 4.x winscp versions). if i connect to an ip in my lan where no ssh server is running, winscp runs in a timeout without leaving me an option to cancel the try of winscp to connect.
here i connect to an local network ip where no ssh server is installed:
<invalid link removed>
also if i know that winscp can't connect because i have to start/install ssh server first i have to wait (in my case 22sec) for winscp to show me the following error window:
and then i only have 5sec to press ok, if a miss to press the ok button i have to wait another 22sec in the "freeze mode" until the error window reappears and i can press ok.
it would be great to let winscp try to connect in backgroud but leaving me the option to cancel the connection try.
http://winscp.net/tracker/show_bug.cgi?id=757
