Topic "Issuing List command to remote directory and output to file"
me119394
I am trying to output the results of a list remote directory command to a text file but I'm getting an error
"Too many parameters for command 'ls'"
Here is the command line:
"C:\Program Files\Winscp\winscp.exe" /console /script=D:\FTP\listtest.txt
Here is the script:
option batch on
open BoxIT
ls /Home/boxit-BDOHR/Test >D:\FTP\lists.txt
ls /Home/boxit-BDOHR/Test2 >D:\FTP\lists2.txt
close
After running the script I get following in console:
Too many parameters for command ls.
If I run the command without the > string then it runs fine, is there a different notation for outputting the results to a file...?
Using WinSCP 4.2.5 on Windows XP.
You cannot redirect output of WinSCP scripts. You can use XML logging instead.
http://winscp.net/eng/docs/logging_xml
Thanks for the reply, I'm not conversant with xml and therefore do not know how to implement this even after going through the examples.
Could you provide a little more guidance on how to implement the xml logging and the elements based upon a "ls" command only wanting the filename & date & time....?
regards
For examples, follow the links at the end of the article.
me119394
Would there be a possibility of this functionality being added in a future version as this would be very handy as an audit trail piece as well for confirmation that the files have reached their destination by attaching this file to an automated smtp email.
I've been trialing another FTP client called COreFTP which has an output function and produces a log file of the transfer of files, I have pasted an example FYI.
2 1 20110406155516 20110406155516 "/Home/Boxit-BDOHR/Test/Brilo.txt" "D:\FTP\test\Brilo.txt"
2 1 20110406155516 20110406155516 "/Home/Boxit-BDOHR/Test/test.txt" "D:\FTP\test\test.txt"
2 1 20110406155516 20110406155516 "/Home/Boxit-BDOHR/Test/test1.xlsx" "D:\FTP\test\test1.xlsx"[/b]
Kind regards
Steve
CountryDave
Here is the script:
option batch on
open BoxIT
close
I found a work around to this limitation.
Lets say that you trying to list the files in a directory that end
with .txt.
Your command would need to be modified as such..
Original:
New:
"C:\Program Files\Winscp\winscp.exe" /console /script=D:\FTP\listtest.txt | find ".txt" > file_list.txt
This new command should pipe the output from the "ls" through the "find" command
and only output the results to file_list.txt.
Now if you want just the file names and not the file permissions, date and other
information, you can download gawk from sourceforge
http://gnuwin32.sourceforge.net/packages/gawk.htm
You will need to create txt.awk file. Inside that file put {print $10} and save it.
Then modify your command to
"C:\Program Files\Winscp\winscp.exe" /console /script=D:\FTP\listtest.txt | find ".txt" | "C:\<path to gawk.exe>" -f 10.awk > file_list.txt
That should produce a file called file_list.txt with just the filenames of
files within a directory that meets the *.txt criteria.
I hope this wasnt too confusing.
CountryDave
Here is the script:
option batch on
open BoxIT
close
with .txt.
Original:
New:
Sorry the final command would be
"C:\Program Files\Winscp\winscp.exe" /console /script=D:\FTP\listtest.txt | find ".txt" | "C:\<path to gawk.exe>" -f txt.awk > file_list.txt
It cannot work with winscp.exe, you have to use winscp.com
Tanveer Munavar
Im trying to run the batch file with below script.
winscp.com/script=C:\Users\Tanveer\Documents\PowerShell\connection_test_new.txt > C:\Users\Tanveer\Documents\test\interface_list.lst
calling below connection_test_new.txt script in the batch file.
# Automatically abort script on errors
option batch abort
# Connect
open adccopd@54.194.250.198
# list the files
ls /development/cop/data/OUTBOUND/COP_INTERFACES/ADD/ARCHIVE
# Disconnect
close
# Exit WinSCP
unfortunately the output is like below .
batch abort
confirm off
Searching for host...
Connecting to host...
Authenticating...
Using username "user".
Authenticated.
Starting the session...
Reading remote directory...
Session started.
Active session: [1] user@example
-rw-r--r-- 1 adccopd infagrp 79 Jun 19 12:46:10 2014 ORD094140616130015.csv
-rw-r--r-- 1 adccopd infagrp 158 Jun 19 12:46:09 2014 ORD092140616130015.csv
drwxrwxr-- 4 copadm infagrp 4096 Mar 21 12:50:38 2014 ..
drwxrwxr-- 2 copadm infagrp 4096 Jun 19 12:46:11 2014 .
Session 'adccopd@54.194.250.198' closed.
No session.
Im expecting a result like this.
d---- 7/10/2014 2:13 PM Archive
-a--- 6/19/2014 12:46 PM 158 ORD092140616130015.csv
-a--- 6/19/2014 12:46 PM 79 ORD094140616130015.csv
Please suggest how this could be accomplished.
WinSCP has fixed ls format. You cannot change it.
If you want custom format, use WinSCP .NET assembly with its Session.ListDirectory method and format the output as you like.
See http://winscp.net/eng/docs/library_session_listdirectory
Check PowerShell example, if you have no other language preference.
