Topic "Timestamp synchronize problem on Windows 7"
KennethParker
Hi!
I'm using WinSCP 4.3.2, in command line mode, to synchronize files from my IIS ftp server. While I was on WinXP, everything worked fine, now I have following problem:
the synchronize command downloads same and same files again, because the timestamp of local files is wrong. But it's not the usual 1 hour offset, the time is almost correct, it's just that the seconds in local file are always set to ":00".
How to solve this issue?
Can you see the seconds in timestamp of the remote files?
KennethParker
Using WinSCP GUI, no. I see only HH:MM.
But when using for example FileZilla, I can see HH:MM:SS of remote files.
Interesting thing is that when I use the same synchronize script on WinXP virtual machine installed on my Win7, the script doesn't download already dowloaded files (with that :00 seconds problem). (And sorry, my FTP server is not IIS, it's Filezilla).
I have sent you an email.
