Topic "searching a commande same as dir >"
abdel
hi,
im using winscp432.com and every thing is ok to connect to an ftps,but i need a commande that will write the content of ftps file in my local computer without deleting it same as dir > test.txt in DOS Command,is it possible or not?i can display the content with ls but as i told to save a copy in a text file without changing it.
thank you
abdel-droussi
im the same user and i forgot to ask if winscp.com accept the command like if then and if so is there a command which can send message?what i need exactly to search the content of directory by :winscp>cd /inbox
winscp>ls test*
after if available send a message if not noneed,is it possible to do that in winscp?if so which commands i have to type?
thanks in advance
abdel wrote:
hi,
thank you
Do you mean that you want to append the source remote file to the end of target local file?
Use get -append for that:
https://winscp.net/eng/docs/scriptcommand_get
winscp>ls test*
thanks in advance
http://winscp.net/eng/docs/script_checking_file_existence
http://winscp.net/eng/docs/guide_automation#results
abdel
bonjour ,
peut etre que j'ai mal exprim en englais,ce que je veux exactement apres la connexion a mon ftps:
option batch on
open ftps://****:*****@****.*****.com:*** -implicit
cd /inbox
ls LEN*(celui va me retourner une valeur si'il existe de fichier sinon 0)
dans le cas ou le fichier existe je veux envoyer un message par email a mon adresse exemple ***@hotmail.com,est ce que ca possible par winscp432(winscp.com)
merci
abdel
