Topic "Connection refused when using localhost ssh tunnel"
rene
I have simple ssh tunnel on localhost. When I try to connect to my ssh server via this tunnel, winscp (.com | .exe) ends with "Connection refused". Direct connection works well, older version of WinSCP (4.0.3.345) works too.
I am running on Windows 7 SP1.
Direct connection to ssh server [works]:
c:\winscp.com
winscp> open user1:pass1word@myserver1
Searching for host...
Connecting to host...
Authenticating...
Using username "mihula".
Authenticated.
Starting the session...
Reading remote directory...
Session started.
Active session: [1] user1@myserver1
winscp>
Connection via tunnel (myserver1 is redirected from port 60017) [fail]:
c:\winscp.com
winscp> open localhost:60017
Network error: Connection refused.
winscp>
Connection via tunnel using WinSCP 4.0.3 [works]:
winscp> open user1:pass1word@localhost:60017
Authenticating...
Using username "user1".
Authenticated.
Session started.
Active session: [1] user1@localhost
Any ideas what I'm doing wrong?
rene
Well now I think the problem is in conflict IPv4 vs. IPv6.
If I use "127.0.0.1" instead of "localhost", winscp is connected properly.
Is there some commandline option (winscp.com script option) for addressfamily settings?
