Topic "Dropbox and other sync support for client settings"
Just discovered this application and was excited to start using it for my FTP transfers. The problem is that I have multiple computers that all need the same settings and saved login info. If the sessions were saved out to a file or files, it would then be easy to sync via Dropbox and never need to sync things manually again. An extra bonus thing that would make this even easier to config would be either detection of Dropbox during install or at least the option to set a destination on where preferences and saved sessions are placed.
You can save your configuration to an INI file:
http://winscp.net/eng/docs/config
