Topic "Copy execution result to linux server"
Dmitriy.Boiko
Hello, guys! I am not much familiar with winscp, and I had not found the answer to my question on the forums.
Description:
I have a program, which extracts data from Oracle (Windows server). Result can be printed both to console and file. Extracted file is VERY big, so there is no possibility to store all the data on Windows. It is also not acceptable to extract data by parts.
Question:
Is there possibility to give extracted data to winscp entrance that it could copy it to the remote linux server via sftp?
Thank you.
Do you mean to upload data fed into standard input of WinSCP?
Dmitriy.Boiko
Yes. Stdout of windows process to the stdin of WinScp and WinScp should write this stream to file...
Dmitriy.Boiko
Josef
If you can login using SSH on the server and can use shell commands, not only SFTP you could use plink!
http://the.earth.li/~sgtatham/putty/0.60/htmldoc/Chapter7.html#plink
Exactly, I would suggest the same.
