Topic "SFTP (SCP): Error listing directory"
rew
I've got 'Error listing directory' message after connection.
If the remote directory is empty (or contains 5-6 files/directories) the listing working perfectly. If the remote directory contains more files, the directory listing is timed out.
Do you have any idea?
Best regards,
rew
(It's working everything well from another location with the same ini file.)
. 2011-04-12 18:14:39.671 --------------------------------------------------------------------------
. 2011-04-12 18:14:39.686 WinSCP Version 4.3.2 (Build 1201) (OS 5.1.2600 Service Pack 3)
. 2011-04-12 18:14:39.686 Login time: 2011. prilis 12. 18:14:39
. 2011-04-12 18:14:39.686 --------------------------------------------------------------------------
. 2011-04-12 18:14:39.686 Session name: cclient@10.1.1.20
. 2011-04-12 18:14:39.686 Host name: 10.1.1.20 (Port: 22)
. 2011-04-12 18:14:39.686 User name: cclient (Password: Yes, Key file: No)
. 2011-04-12 18:14:39.686 Tunnel: No
. 2011-04-12 18:14:39.686 Transfer Protocol: SFTP (SCP)
. 2011-04-12 18:14:39.686 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2011-04-12 18:14:39.686 Proxy: none
. 2011-04-12 18:14:39.686 SSH protocol version: 2; Compression: No
. 2011-04-12 18:14:39.686 Bypass authentication: No
. 2011-04-12 18:14:39.686 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2011-04-12 18:14:39.686 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2011-04-12 18:14:39.686 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2011-04-12 18:14:39.686 SFTP Bugs: -,-
. 2011-04-12 18:14:39.686 Return code variable: Autodetect; Lookup user groups: Yes
. 2011-04-12 18:14:39.686 Shell: default
. 2011-04-12 18:14:39.686 EOL: 0, UTF: 2
. 2011-04-12 18:14:39.686 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2011-04-12 18:14:39.686 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2011-04-12 18:14:39.686 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2011-04-12 18:14:39.686 Cache directory changes: Yes, Permanent: Yes
. 2011-04-12 18:14:39.686 DST mode: 1
. 2011-04-12 18:14:39.718 Looking up host "10.1.1.20"
. 2011-04-12 18:14:39.718 Connecting to 10.1.1.20 port 22
. 2011-04-12 18:14:39.733 Selecting events 63 for socket 580
. 2011-04-12 18:14:39.733 Waiting for the server to continue with the initialisation
. 2011-04-12 18:14:39.733 Looking for incoming data
. 2011-04-12 18:14:39.733 Looking for network events
. 2011-04-12 18:14:39.733 Detected network event
. 2011-04-12 18:14:39.733 Enumerating network events for socket 580
. 2011-04-12 18:14:39.733 Enumerated 18 network events making 18 cumulative events for socket 580
. 2011-04-12 18:14:39.733 Handling network write event on socket 580 with error 0
. 2011-04-12 18:14:39.733 Handling network connect event on socket 580 with error 0
. 2011-04-12 18:14:39.765 Detected network event
. 2011-04-12 18:14:39.765 Enumerating network events for socket 580
. 2011-04-12 18:14:39.765 Enumerated 1 network events making 1 cumulative events for socket 580
. 2011-04-12 18:14:39.765 Handling network read event on socket 580 with error 0
. 2011-04-12 18:14:39.765 Server version: SSH-2.0-OpenSSH_5.3p1 Debian-3ubuntu6
. 2011-04-12 18:14:39.765 We believe remote version has SSH-2 ignore bug
. 2011-04-12 18:14:39.765 Using SSH protocol version 2
. 2011-04-12 18:14:39.765 We claim version: SSH-2.0-WinSCP_release_4.3.2
. 2011-04-12 18:14:39.765 Waiting for the server to continue with the initialisation
. 2011-04-12 18:14:39.765 Looking for incoming data
. 2011-04-12 18:14:39.765 Looking for network events
. 2011-04-12 18:14:39.827 Detected network event
. 2011-04-12 18:14:39.827 Enumerating network events for socket 580
. 2011-04-12 18:14:39.827 Enumerated 1 network events making 1 cumulative events for socket 580
. 2011-04-12 18:14:39.827 Handling network read event on socket 580 with error 0
. 2011-04-12 18:14:39.827 Doing Diffie-Hellman group exchange
. 2011-04-12 18:14:39.827 Waiting for the server to continue with the initialisation
. 2011-04-12 18:14:39.827 Looking for incoming data
. 2011-04-12 18:14:39.827 Looking for network events
. 2011-04-12 18:14:39.921 Detected network event
. 2011-04-12 18:14:39.921 Enumerating network events for socket 580
. 2011-04-12 18:14:39.921 Enumerated 1 network events making 1 cumulative events for socket 580
. 2011-04-12 18:14:39.921 Handling network read event on socket 580 with error 0
. 2011-04-12 18:14:39.921 Doing Diffie-Hellman key exchange with hash SHA-1
. 2011-04-12 18:14:40.343 Waiting for the server to continue with the initialisation
. 2011-04-12 18:14:40.343 Looking for incoming data
. 2011-04-12 18:14:40.343 Looking for network events
. 2011-04-12 18:14:40.390 Detected network event
. 2011-04-12 18:14:40.390 Enumerating network events for socket 580
. 2011-04-12 18:14:40.390 Enumerated 1 network events making 1 cumulative events for socket 580
. 2011-04-12 18:14:40.390 Handling network read event on socket 580 with error 0
. 2011-04-12 18:14:40.780 Selecting events 63 for socket 580
. 2011-04-12 18:14:40.780 Host key fingerprint is:
. 2011-04-12 18:14:40.780 ssh-rsa 2048 bc:52:d6:98:47:d7:d0:83:8d:87:93:62:10:3c:21:68
. 2011-04-12 18:14:40.780 Initialised AES-256 SDCTR client->server encryption
. 2011-04-12 18:14:40.780 Initialised HMAC-SHA1 client->server MAC algorithm
. 2011-04-12 18:14:40.780 Initialised AES-256 SDCTR server->client encryption
. 2011-04-12 18:14:40.780 Initialised HMAC-SHA1 server->client MAC algorithm
. 2011-04-12 18:14:40.780 Waiting for the server to continue with the initialisation
. 2011-04-12 18:14:40.780 Looking for incoming data
. 2011-04-12 18:14:40.780 Looking for network events
. 2011-04-12 18:14:40.858 Detected network event
. 2011-04-12 18:14:40.858 Enumerating network events for socket 580
. 2011-04-12 18:14:40.858 Enumerated 1 network events making 1 cumulative events for socket 580
. 2011-04-12 18:14:40.858 Handling network read event on socket 580 with error 0
! 2011-04-12 18:14:40.858 Using username "cclient".
. 2011-04-12 18:14:40.858 Waiting for the server to continue with the initialisation
. 2011-04-12 18:14:40.858 Looking for incoming data
. 2011-04-12 18:14:40.858 Looking for network events
. 2011-04-12 18:14:40.874 Detected network event
. 2011-04-12 18:14:40.874 Enumerating network events for socket 580
. 2011-04-12 18:14:40.874 Enumerated 1 network events making 1 cumulative events for socket 580
. 2011-04-12 18:14:40.874 Handling network read event on socket 580 with error 0
. 2011-04-12 18:14:40.874 Prompt (6, SSH password, , &Password: )
. 2011-04-12 18:14:40.874 Using stored password.
. 2011-04-12 18:14:40.874 Sent password
. 2011-04-12 18:14:40.874 Waiting for the server to continue with the initialisation
. 2011-04-12 18:14:40.874 Looking for incoming data
. 2011-04-12 18:14:40.874 Looking for network events
. 2011-04-12 18:14:40.968 Detected network event
. 2011-04-12 18:14:40.968 Enumerating network events for socket 580
. 2011-04-12 18:14:40.968 Enumerated 1 network events making 1 cumulative events for socket 580
. 2011-04-12 18:14:40.968 Handling network read event on socket 580 with error 0
. 2011-04-12 18:14:40.968 Access granted
. 2011-04-12 18:14:40.968 Waiting for the server to continue with the initialisation
. 2011-04-12 18:14:40.968 Looking for incoming data
. 2011-04-12 18:14:40.968 Looking for network events
. 2011-04-12 18:14:41.218 Detected network event
. 2011-04-12 18:14:41.218 Enumerating network events for socket 580
. 2011-04-12 18:14:41.218 Enumerated 1 network events making 1 cumulative events for socket 580
. 2011-04-12 18:14:41.218 Handling network read event on socket 580 with error 0
. 2011-04-12 18:14:41.218 Opened channel for session
. 2011-04-12 18:14:41.218 Waiting for the server to continue with the initialisation
. 2011-04-12 18:14:41.218 Looking for incoming data
. 2011-04-12 18:14:41.218 Looking for network events
. 2011-04-12 18:14:41.249 Detected network event
. 2011-04-12 18:14:41.249 Enumerating network events for socket 580
. 2011-04-12 18:14:41.249 Enumerated 1 network events making 1 cumulative events for socket 580
. 2011-04-12 18:14:41.249 Handling network read event on socket 580 with error 0
. 2011-04-12 18:14:41.249 Started a shell/command
. 2011-04-12 18:14:41.249 --------------------------------------------------------------------------
. 2011-04-12 18:14:41.249 Using SFTP protocol.
. 2011-04-12 18:14:41.249 Doing startup conversation with host.
> 2011-04-12 18:14:41.249 Type: SSH_FXP_INIT, Size: 5, Number: -1
> 2011-04-12 18:14:41.249 01,00,00,00,05,
. 2011-04-12 18:14:41.249 Sent 9 bytes
. 2011-04-12 18:14:41.249 There are 0 bytes remaining in the send buffer
. 2011-04-12 18:14:41.249 Looking for network events
. 2011-04-12 18:14:41.249 Timeout waiting for network events
. 2011-04-12 18:14:41.249 Waiting for another 4 bytes
. 2011-04-12 18:14:41.249 Looking for incoming data
. 2011-04-12 18:14:41.265 Detected network event
. 2011-04-12 18:14:41.265 Enumerating network events for socket 580
. 2011-04-12 18:14:41.265 Enumerated 1 network events making 1 cumulative events for socket 580
. 2011-04-12 18:14:41.265 Handling network read event on socket 580 with error 0
. 2011-04-12 18:14:41.265 Received 99 bytes (0)
. 2011-04-12 18:14:41.265 Read 4 bytes (95 pending)
. 2011-04-12 18:14:41.265 Read 95 bytes (0 pending)
< 2011-04-12 18:14:41.265 Type: SSH_FXP_VERSION, Size: 95, Number: -1
< 2011-04-12 18:14:41.265 02,00,00,00,03,00,00,00,18,70,6F,73,69,78,2D,72,65,6E,61,6D,65,40,6F,70,65,
< 2011-04-12 18:14:41.265 6E,73,73,68,2E,63,6F,6D,00,00,00,01,31,00,00,00,13,73,74,61,74,76,66,73,40,
< 2011-04-12 18:14:41.265 6F,70,65,6E,73,73,68,2E,63,6F,6D,00,00,00,01,32,00,00,00,14,66,73,74,61,74,
< 2011-04-12 18:14:41.265 76,66,73,40,6F,70,65,6E,73,73,68,2E,63,6F,6D,00,00,00,01,32,
. 2011-04-12 18:14:41.265 SFTP version 3 negotiated.
. 2011-04-12 18:14:41.265 Unknown server extension posix-rename@openssh.com="1"
. 2011-04-12 18:14:41.265 Unknown server extension statvfs@openssh.com="2"
. 2011-04-12 18:14:41.265 Unknown server extension fstatvfs@openssh.com="2"
. 2011-04-12 18:14:41.265 We believe the server has signed timestamps bug
. 2011-04-12 18:14:41.265 We will use UTF-8 strings for status messages only
. 2011-04-12 18:14:41.265 Limiting packet size to OpenSSH sftp-server limit of 262148 bytes
. 2011-04-12 18:14:41.265 Getting current directory name.
. 2011-04-12 18:14:41.265 Getting real path for '.'
> 2011-04-12 18:14:41.265 Type: SSH_FXP_REALPATH, Size: 10, Number: 784
> 2011-04-12 18:14:41.265 10,00,00,03,10,00,00,00,01,2E,
. 2011-04-12 18:14:41.265 Sent 14 bytes
. 2011-04-12 18:14:41.265 There are 0 bytes remaining in the send buffer
. 2011-04-12 18:14:41.265 Looking for network events
. 2011-04-12 18:14:41.265 Timeout waiting for network events
. 2011-04-12 18:14:41.265 Waiting for another 4 bytes
. 2011-04-12 18:14:41.265 Looking for incoming data
. 2011-04-12 18:14:41.280 Detected network event
. 2011-04-12 18:14:41.280 Enumerating network events for socket 580
. 2011-04-12 18:14:41.280 Enumerated 1 network events making 1 cumulative events for socket 580
. 2011-04-12 18:14:41.280 Handling network read event on socket 580 with error 0
. 2011-04-12 18:14:41.280 Received 57 bytes (0)
. 2011-04-12 18:14:41.280 Read 4 bytes (53 pending)
. 2011-04-12 18:14:41.280 Read 53 bytes (0 pending)
< 2011-04-12 18:14:41.280 Type: SSH_FXP_NAME, Size: 53, Number: 784
< 2011-04-12 18:14:41.280 68,00,00,03,10,00,00,00,01,00,00,00,10,2F,68,6F,6D,65,2F,63,73,6D,73,63,6C,
< 2011-04-12 18:14:41.280 69,65,6E,74,00,00,00,10,2F,68,6F,6D,65,2F,63,73,6D,73,63,6C,69,65,6E,74,00,
< 2011-04-12 18:14:41.280 00,00,00,
. 2011-04-12 18:14:41.280 Real path is '/home/cclient'
. 2011-04-12 18:14:41.280 Listing directory "/home/cclient".
> 2011-04-12 18:14:41.280 Type: SSH_FXP_OPENDIR, Size: 25, Number: 1035
> 2011-04-12 18:14:41.280 0B,00,00,04,0B,00,00,00,10,2F,68,6F,6D,65,2F,63,73,6D,73,63,6C,69,65,6E,74,
. 2011-04-12 18:14:41.280 Sent 29 bytes
. 2011-04-12 18:14:41.280 There are 0 bytes remaining in the send buffer
. 2011-04-12 18:14:41.280 Looking for network events
. 2011-04-12 18:14:41.280 Timeout waiting for network events
. 2011-04-12 18:14:41.280 Waiting for another 4 bytes
. 2011-04-12 18:14:41.280 Looking for incoming data
. 2011-04-12 18:14:41.296 Detected network event
. 2011-04-12 18:14:41.296 Enumerating network events for socket 580
. 2011-04-12 18:14:41.296 Enumerated 1 network events making 1 cumulative events for socket 580
. 2011-04-12 18:14:41.296 Handling network read event on socket 580 with error 0
. 2011-04-12 18:14:41.296 Received 17 bytes (0)
. 2011-04-12 18:14:41.296 Read 4 bytes (13 pending)
. 2011-04-12 18:14:41.296 Read 13 bytes (0 pending)
< 2011-04-12 18:14:41.296 Type: SSH_FXP_HANDLE, Size: 13, Number: 1035
< 2011-04-12 18:14:41.296 66,00,00,04,0B,00,00,00,04,00,00,00,00,
> 2011-04-12 18:14:41.296 Type: SSH_FXP_READDIR, Size: 13, Number: 1292
> 2011-04-12 18:14:41.296 0C,00,00,05,0C,00,00,00,04,00,00,00,00,
. 2011-04-12 18:14:41.296 Sent 17 bytes
. 2011-04-12 18:14:41.296 There are 0 bytes remaining in the send buffer
. 2011-04-12 18:14:41.296 Looking for network events
. 2011-04-12 18:14:41.296 Timeout waiting for network events
. 2011-04-12 18:14:41.296 Waiting for another 4 bytes
. 2011-04-12 18:14:41.296 Looking for incoming data
. 2011-04-12 18:14:56.296 Timeout waiting for network events
. 2011-04-12 18:14:56.296 Waiting for data timed out, asking user what to do.
. 2011-04-12 18:14:56.296 Asking user:
. 2011-04-12 18:14:56.296 Host is not communicating for 15 seconds.
. 2011-04-12 18:14:56.296 Wait for another 15 seconds? ()
. 2011-04-12 18:14:56.796 Pooling for data in case they finally arrives
. 2011-04-12 18:14:56.796 Looking for network events
. 2011-04-12 18:14:56.796 Timeout waiting for network events
. 2011-04-12 18:14:57.296 Pooling for data in case they finally arrives
. 2011-04-12 18:14:57.296 Looking for network events
. 2011-04-12 18:14:57.296 Timeout waiting for network events
. 2011-04-12 18:14:57.655 Attempt to close connection due to fatal exception:
* 2011-04-12 18:14:57.655 Terminated by user.
. 2011-04-12 18:14:57.655 Closing connection.
. 2011-04-12 18:14:57.655 Sending special code: 12
. 2011-04-12 18:14:57.655 Sent EOF message
. 2011-04-12 18:14:57.655 Selecting events 0 for socket 580
* 2011-04-12 18:14:57.671 (ESshFatal) Terminated by user.
* 2011-04-12 18:14:57.671 Error listing directory '/home/cclient'.
