Topic "Can not transfer and copy file to server"
Inst. of Global Concern
While trying to transfer file to the server, it is uploaded as size 0. (0 byte file is uploaded)
And after trying to overwrite it with the same file on the local, it gets a popup with following error message.
<Failure to copy file to remote>
Failure
Error Code:4
Message:Failure
Request Code:6
I don't understand the cause of error as no detail description is mentioned on the popup message
Using WinSCP 4.3.2 on Windows 7 / Transfer Protocol:SFTP-3
Thanks in advance.
Please post a full log file (on Debug 2 level) showing the problem.
Please find debug2 on the following page.
http://pastebin.com/uHBNbXh6
Regards,
Hi
Though I received an e-mail announcing that reply has been posted, actually I can not see the comment.
I would appreciate if you kindly check this.
Thanks.
I have sent you an email.
