Topic "crypting algorithm"
I try to generate password on my own (without using winscp interface) to store it in the .ini file for ftps connection.
I try to find the information in the documantation but i failed. I would know wich crypting algorithm is used to store password into the .ini file (directive Password=). I know the Master password use AES!
"Saved passwords are stored in a manner that they can easily be recovered."
(http://winscp.net/eng/docs/security)
I would know what is exactly the "manner"
Thank you !
enzogan
Sorry, i forgot to login before posting...
You do not have to encrypt the password at all:
http://winscp.net/eng/docs/custom_distribution#distributing_passwords
