Topic "router and WinSCP"
mdesanctis
Dear friends,
WinSCP works very well for transferring my files.
Some days ago I had to install a WI-FI router for personal reasons.
This router disconnects automatically puTTY and WinSCP after 10 minutes of inactivity.
I have been able to avoid this inconvenience in puTTy with
keepalive 300 (seconds).
I would like to do the same in WinSCP.
What shall I do?
I am using the version 4.1.7 (compilation 413) with Windows XP.
I know that it is quite obsolete, but it is very good for my work, apart from this inconvenience.
Maurizio
Please read documentation:
http://winscp.net/eng/docs/ui_login_connection
mdesanctis
Dear Prikryl,
I have solved the problem setting
null packets 180 (seconds).
Tank you very much
Maurizio
