Topic "Password prompt inaccessible after disconnect by Sleep mode"
none
Windows 7 32 bit
WinSCP 4.3.2
Edit a remote file
Computer to sleep
Wake up computer
Two windows shown in task bar (main and editor)
All windows unresponsive, sometimes password prompt visible when cycling through task switcher, but not visible when actually switching.
While main window is front, cannot switch to editor
Thanks for allowing posts without forcing registration..
Thanks for your post. I'll check it.
Virgil
I confirm this annoying behavior.
I'm using WinSCP version 4.2.9 (Build 938) installed on Windows 7 Professional (SP1) 64bit.
I guess this happens only when WinSCP window is maximized.
Is there any patch or a newer version with this issue fixed?
Can you please try to reproduce the problem with 5.0.5 beta?
The problem doesn't occur with 5.0.5 beta release but after the password submission a popup error window is raised with the message: "Invalid access to memory".
After closing the popup, WinSCP seems to work well.
Thank you,
Virgil
WinSCP error.png (235.8 KB) [Download]
Description: Screenshot with error message.
Virgil
Please send me the debug version of WinSCP to redhat_2000 at yahoo dot com.
