Topic "Problem with filesizes in directory listing"
saanvi
Hi!
I use FAR 1.70b2087 and WinSCP plugin 1.6.2. It reports wrong total filesize in directory. Size may be tens Kb larger than the real size. When I select all the files by Insert btn (or, * keypad), it shows correct size. I.e., panel indicates different sizes for same files:
1,343,463 bytes in 261 files (for selection)
1,371,111 bytes in 261 files
This isn't a big problem, but it may be annoying and unexpecting for some cases.
Thanks for your post. I'll check it.
saanvi
It seems to be that FAR counts sizes of directories together with files. Smile Selecting a directories show sizes 512, 1024, etc. It's different from normal FAR panel operations, where selecting directory displays zero size and only count it as a file.
However, total size displays wrong even no directories exist in panel.
Thanks for your investigation.
