Topic ""Host does not exist" for IPv6 host"
sayshh
I have WinSCP 4.3.2 installed on my machine (client). From this machine I'm trying to connect to an IPv6 host using the command line (WinSCP.com). I get an error "Host does not exist".
Using the GUI, I can connect:
Using the console, I can't:
What could be the problem?
sayshh
Below are the logs:
. 2011-05-03 16:43:58.750 --------------------------------------------------------------------------
. 2011-05-03 16:43:58.750 WinSCP Version 4.3.2 (Build 1201) (OS 5.1.2600 Service Pack 3)
. 2011-05-03 16:43:58.750 Login time: Tuesday, May 03, 2011 4:43:58 PM
. 2011-05-03 16:43:58.750 Session name: root@fc00
. 2011-05-03 16:43:58.750 Host name: fc00 (Port: -1)
. 2011-05-03 16:43:58.750 User name: root (Password: No, Key file: No)
. 2011-05-03 16:43:58.750 Tunnel: No
. 2011-05-03 16:43:58.750 Transfer Protocol: SFTP (SCP)
. 2011-05-03 16:43:58.750 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2011-05-03 16:43:58.750 Proxy: none
. 2011-05-03 16:43:58.750 SSH protocol version: 2; Compression: No
. 2011-05-03 16:43:58.750 Bypass authentication: No
. 2011-05-03 16:43:58.750 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2011-05-03 16:43:58.750 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2011-05-03 16:43:58.750 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2011-05-03 16:43:58.750 SFTP Bugs: -,-
. 2011-05-03 16:43:58.750 Return code variable: Autodetect; Lookup user groups: Yes
. 2011-05-03 16:43:58.765 Shell: default
. 2011-05-03 16:43:58.765 EOL: 0, UTF: 2
. 2011-05-03 16:43:58.765 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2011-05-03 16:43:58.765 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2011-05-03 16:43:58.765 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2011-05-03 16:43:58.765 Cache directory changes: Yes, Permanent: Yes
. 2011-05-03 16:43:58.765 DST mode: 1
. 2011-05-03 16:43:58.765 --------------------------------------------------------------------------
. 2011-05-03 16:43:58.765 Looking up host "fc00"
Thanks for your post. This issue has been added to tracker.
Also, please can you register on the forum or send me an email, so I can send you development version with the fix for testing?
sayshh
I've sent you a mail. Looking forward to the "fix".
sayshh
I've checked with the experimental version and it works! Here is the log (snippet):
. 2011-05-06 15:58:48.214 --------------------------------------------------------------------------
. 2011-05-06 15:58:48.214 WinSCP Version 4.3.2 (Build 1202) (OS 5.1.2600 Service Pack 3)
. 2011-05-06 15:58:48.214 Login time: Friday, May 06, 2011 3:58:48 PM
. 2011-05-06 15:58:48.214 Session name: root@fc00:1<masked out>6:d9ee
. 2011-05-06 15:58:48.214 Host name: fc00:1<masked out>6:d9ee (Port: 22)
. 2011-05-06 15:58:48.214 User name: root (Password: Yes, Key file: No)
. 2011-05-06 15:58:48.214 Tunnel: No
. 2011-05-06 15:58:48.214 Transfer Protocol: SFTP (SCP)
. 2011-05-06 15:58:48.214 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2011-05-06 15:58:48.214 Proxy: none
. 2011-05-06 15:58:48.214 SSH protocol version: 2; Compression: No
. 2011-05-06 15:58:48.214 Bypass authentication: No
. 2011-05-06 15:58:48.214 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2011-05-06 15:58:48.214 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
sayshh
Hi Martin,
Seems like the developmental version you sent isn't portable, or doesn't work the same way on different Operating Systems. When I first reported the issue, I was on Windows XP (you could tell from the screenshots). When I used your developmental version on that machine it worked fine.
However, I copied it (WinSCP.exe) to another machine with Windows 2003 Server installed, used the command:
WinSCP.exe /console /script=TestFile.txt /log=c:\scplog.txt
Copy failed! Below is the log:
. 2011-05-12 02:46:36.389 --------------------------------------------------------------------------
. 2011-05-12 02:46:36.389 WinSCP Version 4.3.2 (Build 1202) (OS 5.2.3790 Service Pack 2)
. 2011-05-12 02:46:36.389 Login time: Thursday, May 12, 2011 2:46:36 AM
. 2011-05-12 02:46:36.389 Session name: root@fc00:1<masked out>6:d9ee
. 2011-05-12 02:46:36.389 Host name: fc00:1<masked out>6:d9ee (Port: 22)
. 2011-05-12 02:46:36.389 User name: root (Password: Yes, Key file: No)
. 2011-05-12 02:46:36.389 Tunnel: No
. 2011-05-12 02:46:36.389 Transfer Protocol: SFTP (SCP)
. 2011-05-12 02:46:36.389 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2011-05-12 02:46:36.389 Proxy: none
. 2011-05-12 02:46:36.389 SSH protocol version: 2; Compression: No
. 2011-05-12 02:46:36.389 Bypass authentication: No
. 2011-05-12 02:46:36.389 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2011-05-12 02:46:36.389 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2011-05-12 02:46:36.389 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2011-05-12 02:46:36.389 SFTP Bugs: -,-
. 2011-05-12 02:46:36.389 Return code variable: Autodetect; Lookup user groups: Yes
. 2011-05-12 02:46:36.389 Shell: default
. 2011-05-12 02:46:36.389 EOL: 0, UTF: 2
. 2011-05-12 02:46:36.389 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2011-05-12 02:46:36.389 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2011-05-12 02:46:36.389 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2011-05-12 02:46:36.389 Cache directory changes: Yes, Permanent: Yes
. 2011-05-12 02:46:36.389 DST mode: 1
. 2011-05-12 02:46:36.389 Looking up host "fc00:1<masked out>6:d9ee"
After this nothing happened. Will the fully installable version (4.3.3) be free of such issues? Is it because I'm running just the binary (no dll or other files)?
