Topic "How to adjust DST in using .net"
Ahsan Shakir
I am developing a SFTP software. But Last modified date time is different on both remote(winscp) and local directory(folder explore).
Can you please give me example how to "adjust remote timestamp with DST" in .net?
I will be greatful to you
Ahsan Shakir
I do not know the command which adjust the UK DST.
it will be great, if you provide me exact DST to adjust to the system.
Basically, I check last modified datetime into log file. If it is new LMDT then download.
I am keen to know, which script code will adjust the last modified datetime with respect to DST into the logfile.
