Topic "Script doesn't work in one case"
tbohon
I have over a dozen WinSCP scripts working just fine. However a new one just implemented isn't working properly and I'm out of ideas.
Here is the script code:
open PGroup
pwd
lcd d:\mywork
lls *.dat
put -nopreservetime -nopermissions *.dat
dir *.dat
The script above is called by this command:
winscp.com /script=d:\scp_scripts\pgroup.scp
The scp log shows that everything is fine until I get to the 'put' command. Nothing happens and the script quietly and properly terminates.
I can do the transfer manually from the command line using winscp.com and every command works fine. I can do it manually using the GUI and I receive a complaint about permissions but the file transfers.
Any and all ideas and suggestions would be most appreciated - this is making me crazy!!! Shocked
Thanks in advance.
Tom
tbohon
While getting the log files Martin requested I stumbled on the fact that the production script, unlike my test script, was running as a different user inside the Windows Scheduler. Although that user and my (personal) user are in the same groups and have the same 'admin level' permissions on the Win2003 Server as soon as I changed the user to my own the script ran correctly. I have a question in to my server engineer now to confirm that the two users have the exact same permissions but I'll bet $$$ that this is the problem.
Anyway, first real test is early tomorrow morning when, under the Windows scheduler, the production script will run 'hands off' with me as the 'owner' of the scheduler entry.
If that doesn't work I'll be back here whimpering a lot ... Wink
Thanks.
Tom
Please read FAQ:
http://winscp.net/eng/docs/faq_scheduler
tbohon
Thanks Martin ... I'll do further research as we start converting all of my 150+ scripts over to the service account since I don't plan on working here the rest of my life anyway ... I hope ... maybe ... if I'm lucky ... Very Happy
