Topic "Could not retrive directory listing using command scripting."
umbe
I'm trying to synch local dirs to remote ftp, and using the GUI version all works fine but If I try to use the commands scripting I get the following error (from log):
. 2011-05-05 13:41:53.474 --------------------------------------------------------------------------
. 2011-05-05 13:41:53.475 WinSCP Version 4.2.9 (Build 938) (OS 6.1.7600)
. 2011-05-05 13:41:53.475 Login time: gioved 5 maggio 2011 13:41:53
. 2011-05-05 13:41:53.475 --------------------------------------------------------------------------
. 2011-05-05 13:41:53.475 Session name: jack@192.168.229.40
. 2011-05-05 13:41:53.476 Host name: 192.168.229.40 (Port: 21)
. 2011-05-05 13:41:53.476 User name: jack (Password: Yes, Key file: No)
. 2011-05-05 13:41:53.476 Tunnel: No
. 2011-05-05 13:41:53.477 Transfer Protocol: FTP
. 2011-05-05 13:41:53.477 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2011-05-05 13:41:53.477 Proxy: none
. 2011-05-05 13:41:53.477 FTP: FTPS: None; Passive: No [Force IP: No]
. 2011-05-05 13:41:53.477 Local directory: default, Remote directory: /jack/BCK-192.168.231.215/test, Update: No, Cache: Yes
. 2011-05-05 13:41:53.477 Cache directory changes: Yes, Permanent: Yes
. 2011-05-05 13:41:53.478 DST mode: 1
. 2011-05-05 13:41:53.478 --------------------------------------------------------------------------
. 2011-05-05 13:41:53.483 Connecting to 192.168.229.40 ...
. 2011-05-05 13:41:53.484 Connected with 192.168.229.40. Waiting for welcome message...
< 2011-05-05 13:41:53.485 220 Microsoft FTP Service
> 2011-05-05 13:41:53.485 USER jack
< 2011-05-05 13:41:53.485 331 Password required for jack.
> 2011-05-05 13:41:53.486 PASS **************
< 2011-05-05 13:41:53.489 230 User logged in.
> 2011-05-05 13:41:53.489 SYST
< 2011-05-05 13:41:53.489 215 Windows_NT
> 2011-05-05 13:41:53.489 FEAT
< 2011-05-05 13:41:53.490 211-Extended features supported:
< 2011-05-05 13:41:53.490 LANG EN*
< 2011-05-05 13:41:53.490 UTF8
< 2011-05-05 13:41:53.490 AUTH TLS;TLS-C;SSL;TLS-P;
< 2011-05-05 13:41:53.490 PBSZ
< 2011-05-05 13:41:53.490 PROT C;P;
< 2011-05-05 13:41:53.490 CCC
< 2011-05-05 13:41:53.491 HOST
< 2011-05-05 13:41:53.491 SIZE
< 2011-05-05 13:41:53.491 MDTM
< 2011-05-05 13:41:53.491 REST STREAM
< 2011-05-05 13:41:53.491 211 END
> 2011-05-05 13:41:53.491 OPTS UTF8 ON
< 2011-05-05 13:41:53.491 200 OPTS UTF8 command successful - UTF8 encoding now ON.
. 2011-05-05 13:41:53.491 Connected
. 2011-05-05 13:41:53.492 Got reply 1 to the command 1
. 2011-05-05 13:41:53.492 --------------------------------------------------------------------------
. 2011-05-05 13:41:53.492 Using FTP protocol.
. 2011-05-05 13:41:53.495 Doing startup conversation with host.
> 2011-05-05 13:41:53.495 PWD
< 2011-05-05 13:41:53.496 257 "/jack" is current directory.
. 2011-05-05 13:41:53.496 Got reply 1 to the command 16
. 2011-05-05 13:41:53.497 Changing directory to "/jack/BCK-192.168.231.215/test".
> 2011-05-05 13:41:53.497 CWD /jack/BCK-192.168.231.215/test
< 2011-05-05 13:41:53.499 250 CWD command successful.
. 2011-05-05 13:41:53.499 Got reply 1 to the command 16
. 2011-05-05 13:41:53.499 Getting current directory name.
> 2011-05-05 13:41:53.499 PWD
< 2011-05-05 13:41:53.500 257 "/jack/BCK-192.168.231.215/test" is current directory.
. 2011-05-05 13:41:53.500 Got reply 1 to the command 16
. 2011-05-05 13:41:53.500 Startup conversation with host finished.
< 2011-05-05 13:41:53.500 Script: Active session: [1] jack@192.168.229.40
. 2011-05-05 13:41:53.501 Session upkeep
> 2011-05-05 13:41:53.501 Script: option transfer binary
< 2011-05-05 13:41:53.501 Script: transfer binary
> 2011-05-05 13:41:53.502 Script: option include "*.*"
< 2011-05-05 13:41:53.502 Script: include *.*
. 2011-05-05 13:41:53.502 Session upkeep
> 2011-05-05 13:41:53.502 Script: synchronize remote -criteria=size -mirror -delete D:\backup\test"
< 2011-05-05 13:41:53.503 Script: Comparing...
. 2011-05-05 13:41:53.503 Collecting synchronization list for local directory 'D:\backup\test' and remote directory '/jack/BCK-192.168.231.215/test', mode = 0, params = 5635
. 2011-05-05 13:41:53.505 Retrieving directory listing...
> 2011-05-05 13:41:53.505 TYPE A
< 2011-05-05 13:41:53.506 200 Type set to A.
> 2011-05-05 13:41:53.507 PORT 95,110,231,215,195,5
< 2011-05-05 13:41:53.508 200 PORT command successful.
> 2011-05-05 13:41:53.508 LIST -a
< 2011-05-05 13:41:53.510 150 Opening ASCII mode data connection.
. 2011-05-05 13:42:08.684 Timeout detected.
. 2011-05-05 13:42:08.684 Could not retrieve directory listing
. 2011-05-05 13:42:08.684 Got reply 1004 to the command 2
this is my command:
C:\Users\Administrator\Desktop\WinSCPPortable\WinSCPPortable.exe /console /log="C:\Users\Administrator\Desktop\WinSCPPortable\LOG.LOG" /command "option batch on" "option confirm off" "open ftp://jack:!PWD!@192.168.229.40/jack/BCK-192.168.231.215/test" "option transfer binary" "option include ""*.*""" "synchronize remote -criteria=size -mirror -delete "D:\backup\test"" exit
any suggestion?
Using the GUI I'm sure I'm using the PASSIVE mode, I think that also with the scripts is using the passive mode
umbe
Sorry guys to up this thread...
any suggestion?
Thx a lot
bye
The script is not using passive mode as you can see in the log. Use -passive switch with open command.
