Topic "Slow and unresponsive windows"
Hi there,
I'm running WinSCP 3.5.0 (build 204) and I'm finding that the program is slow and unresponsive, especially when transferring a file.
Windows take seconds to minimise/restore and the general interface is "chuggy".
I'm running a Evo N1020v laptop (P4 w/ 768 MB RAM) and running WinXP pro.
Any help would be greatly appreciated.
Cheers.
Well, this is feature, not bug Smile You cannot do anything with it.
So you're saying this is a limitation of the software?
Is there a timeline for when this "feature" is going to be "superceded"? Smile
Currently I do not plan it at all, sorry Sad
Sven
Are you serious about this being a "feature" that is not planned to be straightened out any time soon? The slow GUI response is horrible, and it happens even on fast computers. It takes *3 seconds* approx to raise the minimized winscp window when it is copying files. What is the cause of this lag?
Sven
A little more searching found this post in the forum where Halfgaar suggests disabling the 'webclient' service in XP. This actually helped quite a bit; now the lagging in the GUI isn't that severe. It is strange, though, that this should pose a problem.
