Topic "files invisible"
Hi there,
after opening the session to see what is at the /(root) - directory of the server I can only see all folders but not the files in them. What is wrong?
If I use WS_FTP the files in the directories of my test customer are visible.
My intention is to change the index.html site that appears if the site have been called.
Because of restrictive orders an secure reasons this is not possible whith WS_PTP.
I use SFTP.
Is there a good solution perhaps?
You mean that when you enter the directory, the remote panel is empty (with exception of ".." parent link)? Or do you see subdirectories there (if any), but not the files? If the first is ture, than you may not have permisions to list the directory. (the fact that it you see them with FTP may not mean that you should see them with SFTP).
