Topic "Edit session properties window"
swbrains
New WinSCP FTP user here... Looks like a great app so far!
When you first start WinSCP , a Login box appears that allows you to choose a saved session and also to edit its properties.
Once logged in, how do you invoke this dialog again? That is, how do I get the "saved session property edit" dialog? I couldn't seem to find a menu option or a toolbar button to bring it back up.
Thanks!
You cannot edit options of currently connected session. If that's what you ask for. You need to disconnect (you get a login dialog than, if it was the last opened session), edit and connect again.
Anyway, you can open the login dialog by going to Session > New Session.
See also here:
http://winscp.net/eng/docs/task_connections
