Topic "How to pass proxyhost in command line (script.txt)"
Janardhanan
i want to pass proxy value in command line
currently the command to open sftp like,
open sftp://user:password@hostname:port
but, i want to add proxy name also in command line...
is it possible to add proxyname also?
"ProxyHost=proxyhost.test.com"
suppose i open winscp.exe directly means i can add proxy host also
but in the script.txt i am not able to add proxyhost name...
pls help me...
Jana
Please read FAQ:
http://winscp.net/eng/docs/faq_script_ini
Janardhanan
i want to pass hostname,username,password and also proxyhost using open script command... i dont want to use stored session.
i am able to pass username, password, hostname and port using script to connect ftp server. now i want to connect sftp command. my sftp has proxy settings also can you give me a suggestion to passing proxy as argument. i have attached my ftp script code
option batch on
open ftp://username:password@hostname:port
cd "out
option transfer binary
get Test.zip MyTest.zip
close
but, i want to connect sftp with proxy host
suppose i will use to refere ini files for setting proxy host value where i can mention the password. because in ini file password is encrypted. so i am not able to mention the password in configuration settings. or suppose i didnt mention the password means winscp prompt me to enter the password. so how can i pass the password with command line directly..
kindly help me to solve my issue..
jana
Janardhanan
option batch on
cd "out
close
jana
pls solve my issue... i am working with .net using C#
Janardhanan
option batch on
cd "out
close
jana
GeorgeM
It is really easy Cool
Example:
Proxy address: myproxy.net (or ip address of proxy: 195.195.195.32)
FTP address: myftp.syte.org (or ip address of ftp: 10.10.10.33)
User name for ftp: NA\S029088
Pass: easyftpproxy
connection:
start command prompt: run - > cmd
open ftp - type 'ftp' and press Enter: ftp (enter)
c:\ftp
ftp> open myproxy.net
ftp> NA\S029088@myftp.syte.org
ftp>easyftpproxy
230 User NA\S029088 logged in.
ftp>bye
c:\
Mr. Green
david9988
HI,
AND USING PORT 8080 WOW DO YOU INCLUDE THAT ?
THANKS
Example:
Pass: easyftpproxy
connection:
c:\ftp
ftp>easyftpproxy
ftp>bye
c:\
Mr. Green
