Topic "SSIS ...process exit code was "1" while the expected was "0""
I'm having issues executing from an Execute Process Task in SSIS. If the file doesn't exist in the destination server, the package runs successful, if the file does exist in the destination server I get the error:
[Execute Process Task] Error: In Executing "C:\Winscp\" "/command "option confirm off" /log=C:\Winscp\Logs\2011-06-08.125002.xml" at "", The process exit code was "1" while the expected was "0".
The contents from the log file is the following (in both cases of failure and success, the log is the same with the exception of the time):
<session xmlns="" name="ftpservername" start="2011-06-08T15:50:02.692Z">
<filename value="\\xxxservername\xxxfilename.xls" />
<destination value="filename.xls" />
<result success="true" />
Not sure what the problem is.
Can you post plain log file, instead of the XML one?
