Topic "WinSCP Blocked"
sbeltrami
I have this problem below :
150 Opening BINARY mode data connection for 5871498.tif(58195 bytes).
. 2011-06-10 17:10:52.024 Timeout detected.
. 2011-06-10 17:10:52.024 Copying files from remote side failed.
. 2011-06-10 17:10:52.024 Got reply 1004 to the command 4
. 2011-06-10 17:10:52.024 Connection was lost, asking what to do.
. 2011-06-10 17:10:52.024 Asking user:
. 2011-06-10 17:10:52.024 Lost connection. ("Timeout detected.","Copying files from remote side failed.","Opening BINARY mode data connection for 5871498.tif(58195 bytes).")
< 2011-06-10 17:10:58.275 Script: Connecting to XXX.XXX.XXX.XXX ...
. 2011-06-10 17:10:58.275 Connecting to XXX.XXX.XXX.XXX ...
. 2011-06-10 17:11:19.213 A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
. 2011-06-10 17:11:19.213 Connection failed.
. 2011-06-10 17:11:19.213 Got reply 1004 to the command 1
. 2011-06-10 17:11:19.213 Connection was lost, asking what to do.
. 2011-06-10 17:11:19.213 Asking user:
. 2011-06-10 17:11:19.213 Connection failed. ("A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.","Connection failed.")
. 2011-06-10 17:11:25.463 Getting current directory name.
it is a script and process winscp.exe does not exit with error but it remains hold without any response.
Can anyone halp me?
What does your script look like?
sbeltrami
we call:
winscp.exe SessionName /ini=WinSCP.ini /console /script=get.txt
Script file (get.txt) has the following commands:
option batch continue
option exclude *.tif<100b
option transfer binary
cd destinationfolder
get -delete *.tif destinationfolder
close
where destinationfolder is a local path (ex: D:\....)
I have sent you an email.
