Topic "Disable deleting files from server when using example.js"
PeteTheBeagle
I'm using the example.js script from your web site by running cscript /nologo example.js and it works great. The only changes I made to the script are my session name and the folder names. It determines the latest file and downloads it successfully but I want it to leave the original file on the server.
How do I stop it from deleting any files from my SFTP server??
I looked at the script and its doing a regular get without any -delete options:
exec.StdIn.Write(
"option batch abort\n" +
"option confirm off\n" +
"open \"" + SESSION + "\"\n" +
"get \"" + REMOTEPATH + filenameLatest + "\" \"" + LOCALPATH + "\"\n" +
"exit\n");
I'm using INI storage if that makes a difference, with all default settings in the user interface. What am I missing?
This script should not delete any file. If it does, please post a log file.
