Topic "WinSCP stop on opening channel"
SaloS
I have starnge issue. Yesterday everything works fine but today winscp don't want to connect to by ubuntu server. It stops on opening channel for session after authentication
Log
. 2011-06-30 09:33:03.758 --------------------------------------------------------------------------
. 2011-06-30 09:33:03.758 WinSCP Version 4.3.3 (Build 1340) (OS 5.1.2600 Service Pack 3)
. 2011-06-30 09:33:03.758 Configuration: HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\
. 2011-06-30 09:33:03.758 Login time: 30 ╚■э№ 2011 у. 9:33:03
. 2011-06-30 09:33:03.758 Session name: release new (Stored session)
. 2011-06-30 09:33:03.758 Host name: 88.212.206.106 (Port: 22)
. 2011-06-30 09:33:03.774 User name: toor (Password: Yes, Key file: No)
. 2011-06-30 09:33:03.774 Tunnel: No
. 2011-06-30 09:33:03.774 Transfer Protocol: SFTP (SCP)
. 2011-06-30 09:33:03.774 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2011-06-30 09:33:03.774 Proxy: none
. 2011-06-30 09:33:03.774 SSH protocol version: 2; Compression: No
. 2011-06-30 09:33:03.774 Bypass authentication: No
. 2011-06-30 09:33:03.774 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2011-06-30 09:33:03.774 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2011-06-30 09:33:03.774 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2011-06-30 09:33:03.774 SFTP Bugs: -,-
. 2011-06-30 09:33:03.774 Return code variable: Autodetect; Lookup user groups: Yes
. 2011-06-30 09:33:03.774 Shell: default
. 2011-06-30 09:33:03.774 EOL: 0, UTF: 2
. 2011-06-30 09:33:03.774 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2011-06-30 09:33:03.774 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2011-06-30 09:33:03.774 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2011-06-30 09:33:03.774 Cache directory changes: Yes, Permanent: Yes
. 2011-06-30 09:33:03.774 DST mode: 1
. 2011-06-30 09:33:03.774 --------------------------------------------------------------------------
. 2011-06-30 09:33:03.805 Looking up host "88.212.206.106"
. 2011-06-30 09:33:03.805 Connecting to 88.212.206.106 port 22
. 2011-06-30 09:33:04.211 Server version: SSH-2.0-OpenSSH_5.8p1 Debian-1ubuntu3
. 2011-06-30 09:33:04.211 We believe remote version has SSH-2 ignore bug
. 2011-06-30 09:33:04.211 Using SSH protocol version 2
. 2011-06-30 09:33:04.211 We claim version: SSH-2.0-WinSCP_release_4.3.3
. 2011-06-30 09:33:04.430 Doing Diffie-Hellman group exchange
. 2011-06-30 09:33:04.852 Doing Diffie-Hellman key exchange with hash SHA-1
. 2011-06-30 09:33:05.289 Host key fingerprint is:
. 2011-06-30 09:33:05.289 ssh-rsa 2048 97:5a:10:88:58:99:0d:e0:63:d8:aa:6a:c4:46:26:57
. 2011-06-30 09:33:05.289 Initialised AES-256 SDCTR client->server encryption
. 2011-06-30 09:33:05.289 Initialised HMAC-SHA1 client->server MAC algorithm
. 2011-06-30 09:33:05.289 Initialised AES-256 SDCTR server->client encryption
. 2011-06-30 09:33:05.289 Initialised HMAC-SHA1 server->client MAC algorithm
! 2011-06-30 09:33:05.727 Using username "toor".
. 2011-06-30 09:33:05.930 Prompt (7, SSH password, , &Password: )
. 2011-06-30 09:33:05.930 Using stored password.
. 2011-06-30 09:33:05.930 Sent password
. 2011-06-30 09:33:06.149 Access granted
. 2011-06-30 09:33:06.336 Opened channel for session
. 2011-06-30 09:33:21.337 Waiting for data timed out, asking user what to do.
. 2011-06-30 09:33:21.337 Asking user:
. 2011-06-30 09:33:21.337 Host is not communicating for 15 seconds.
. 2011-06-30 09:33:21.337 Wait for another 15 seconds? ()
. 2011-06-30 09:33:27.993 Attempt to close connection due to fatal exception:
* 2011-06-30 09:33:27.993 Terminated by user.
. 2011-06-30 09:33:27.993 Closing connection.
. 2011-06-30 09:33:27.993 Sending special code: 12
* 2011-06-30 09:33:27.993 (ESshFatal) Terminated by user.
* 2011-06-30 09:33:27.993 Authentication log (see session log for details):
* 2011-06-30 09:33:27.993 Using username "toor".
* 2011-06-30 09:33:27.993 Authentication failed.
Putty works fine, but WinSCP does not.
I set 'UseDNS no' on my ssh server but it does not help.
Other similar Ubuntu servers still work fine. (but they are 10.4 and this one is 11.4)
What version of PuTTY are you using? Can you try the latest development snapshot?
