winscp 4.3.3 gui dies in TS session under XP
pjn
I have a Win XP Pro (SP3+updates) machine accessed only via an RDP session and WinSCP 4.3.3
If I leave the WinSCP window open in the session and disconnect/reconnect at a later time the WinSCP gui has died with only window boundary showing and not operable. Terminating app in Task Manager is only way out. It dies in idle or transferring files state.
If I minimise WinSCP before disconnecting from the RDP session I can maximise it on return and it is still working. It works this way in idle or transferring files state.
Cheers
Petar
pjn
Re: winscp 4.3.3 gui dies in TS session under XP
In addition this occurs regardless of gui interface mode or transfer protocol selected.
Cheers
Petar
