Renaming sessions
Ricardo
Ricardo avatar
Renaming sessions
Hi Martin, how are you?
Today, I decided to rename one stored session because I changed the name of one user on my server...
After renaming the session, editing the login user and overwriting the saved session, when I connected all bookmarks (aka. Location Profiles) didn't work anymore (it was displayed an empty list).
I then needed to manually edit WinSCP.ini to replace occurrences of user@ip with newuser@ip to get bookmarks working again for that session.
Re: Renaming sessions
Ok, so it is probably not about renaming the session, but about changing login user, right? The bookmarks are stored per-login user/host.
