Topic "FTPS upload trough proxy truncate files"
liron
Files uploaded using FTPS protocol via proxy, arrive truncated to remote host. Small files are totally truncated to 0 bytes. Bigger files are truncated to 'binary blocks' like 16384 bytes. No error messages generated, normal "Upload successful" in log.
Tested from a Windows XP SP3 with WinSCP 4.3.3
Problem happens using FTP over SSL or TLS with explicit encription, and not with SFTP, SCP or plain FTP.
Tested and reproducible with HTTP proxy, SOCKS4 and SOCKS5. No problem if direct connection without proxy.
Maybe related, but different to
"File trx via FTP through SSH proxy corrupts uploaded files" (http://winscp.net/forum/viewtopic.php?t=5517)
or
Tracker Bug 245 "Files uploaded over FTP with SOCKS5 proxy gets corrupted"
Does it work using other FTP client?
liron
Is there any other FTP client? Wink
Seriously, there are few free clients implementing FTPS and proxy features.
In a debian linux machine lftp and cURL clients works correctly using HTTP proxy. Tested also SOCKS4 & SOCKS5 with curl, no problem here.
bstoney
I know this is an old post, however we are having this issue. We have only recently started using a proxy an all file transfers were working correctly without the proxy. All bytes are transferred for files downloaded over FTPS, however uploaded files are truncated or 0 bytes for small files.
We have tested using FileZilla and the files are transferred correctly, but need a command line and were using winscp.com
Regards
liron
Could you send me a debug version, too?
Thanks for getting back to me. Email sent.
http://winscp.net/tracker/show_bug.cgi?id=1092
bstoney
Thanks Martin, I've tested the fix and it worked.
ycdzvp2
Can the patched version of 5.1.8 or a debug version containing this fix be made available?
The fix is also included in 5.2.7 RC (released already).
