Topic "SSIS Execute Process task with Password including @"
rama
I am trying to connect to SFTP using execute process task with inputstandardvariable as a variable which has a command
option batch on
open sftp://Username:Password@123@sftp.compassphs.com
lcd \\network\Temp\
option transfer automatic
get /home/Test/*.txt
This command works absolutely fine,but if there is an '@' in the password,i am not able to get the files,the package fails.Could you please tell ma workaround.
Rama
Please read documentation:
http://winscp.net/eng/docs/session_url
