Topic "Configuration Files"
tonjab
We have WinSCP set up to use .ini config files. Yet when I run the SSIS package and check the logfile it creates it seems to be using the registry.
--- SSIS Process Task
Executable: C:\Program Files (x86)\WinSCP\WinSCP.exe
Arguments: -script=D:\SSIS\ETitleFiles\FDIImportScript.txt -log=D:\SSIS\ETitleFiles\import.log
Working Directory: D:\SSIS\ETitleFiles\
--- WinSCP Script File
option batch on
open fdielt
lcd D:\SSIS\ETitleFiles\Import\
cd /upload
get *.UP
--- Latest Log File
2011-07-27 12:46:39.969 --------------------------------------------------------------------------
. 2011-07-27 12:46:39.969 WinSCP Version 4.3.3 (Build 1340) (OS 6.1.7600)
. 2011-07-27 12:46:39.969 Configuration: HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\
. 2011-07-27 12:46:39.969 Login time: Wednesday, July 27, 2011 12:46:39 PM
. 2011-07-27 12:46:39.969 --------------------------------------------------------------------------
. 2011-07-27 12:46:39.969 Session name: fdielt (Ad-Hoc session)
. 2011-07-27 12:46:39.969 Host name: fdielt (Port: 22)
. 2011-07-27 12:46:39.969 User name: (Password: No, Key file: No)
. 2011-07-27 12:46:39.969 Tunnel: No
. 2011-07-27 12:46:39.969 Transfer Protocol: SFTP (SCP)
. 2011-07-27 12:46:39.969 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2011-07-27 12:46:39.969 Proxy: none
. 2011-07-27 12:46:39.969 SSH protocol version: 2; Compression: No
. 2011-07-27 12:46:39.969 Bypass authentication: No
. 2011-07-27 12:46:39.969 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2011-07-27 12:46:39.969 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2011-07-27 12:46:39.969 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2011-07-27 12:46:39.969 SFTP Bugs: -,-
. 2011-07-27 12:46:39.969 Return code variable: Autodetect; Lookup user groups: Yes
. 2011-07-27 12:46:39.969 Shell: default
. 2011-07-27 12:46:39.969 EOL: 0, UTF: 2
. 2011-07-27 12:46:39.970 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2011-07-27 12:46:39.970 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2011-07-27 12:46:39.970 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2011-07-27 12:46:39.970 Cache directory changes: Yes, Permanent: Yes
. 2011-07-27 12:46:39.970 DST mode: 1
. 2011-07-27 12:46:39.970 --------------------------------------------------------------------------
. 2011-07-27 12:46:39.970 Looking up host "fdielt"
So is there C:\Program Files (x86)\WinSCP\WinSCP.ini ?
