Topic "Cannot delete files, receving error message"
earwig
I have checked the FAQ and forum several times for this question but I am not getting anywhere; could someone please help? When I try to delete a folder from the remote server I receive an error message:
Error moving file 'testfile.txt' to '/tmp/testfile-20110728-144157.txt'. General failure (server should provide error description). Error code: 4 Error message from server: Failure Request code: 18
I am guessing that it is trying to move the file to a tmp directory to use as a recycle bin, but I don't want to move the file to a recycle bin on the server, I want to simply delete it. Is there a setting I can change in the WinSCP options?
Thank you very much.
earwig
I meant to say... I am trying to delete a FILE not a folder. Thanks again for any help you can provide.
Please read documentation:
http://winscp.net/eng/docs/ui_login_recycle_bin
Alejandro Gavilanes
Had same problem as you reported and after a bit of trouble shooting found that it was caused by our linux server not having the /tmp/ directory on root.
To fix this in my case I had to point WinSCP session settings (advanced tab) and change the path of the Remote recycle bin, to a valid location.
Other option I suspect is create a folder on linux root called tmp, if you have access.
